Page 114 of 119
Re: Aarons Drag CQ: 12-25 pedals are almost completed
Posted: Wed Dec 26, 2012 8:27 pm
by lxnadeau
looking good! btw where did you get the braking/clutch reservoir? and i love you fusebox set up, i will build mine similar to yours
Sent from a Galaxy SII using Tapatalk
Posted: Wed Dec 26, 2012 8:53 pm
by speeding-g60
thanks! but i am going really slow working on the car these past months. the day after tomorrow, this happens. then it will be RADIO SILENCE for quite a while. but the plan is to run 8 seconds next season.... if i live that is. because of this herniated disc problem, the last time i drove the car i had to quit early and was almost in tears and crawling it hurt so bad. i endured 5 passes and gave up, broken.
and the reservoir came from Summit Racing.
i did the all new front brake lines, now i just have to hook the line from the rear master to the staging brake and the rears are done too.
but this is what i am looking forward to in two days, not super excited about it, but needs done i guess. one thing that troubles me is the fact that they will remove the complete lamina instead of make a small hole in the passageway. another is the fact that they will be moving my spinal cord around some. sketchy stuff....
Posted: Wed Dec 26, 2012 9:07 pm
by PRA4WX
Sketchy is right. Good luck, buddy. I hope to see you making passes again soon. Keep us posted on your recovery. :cheers:
by ChrisAudi80
Wow. Good luck and all the best.
Posted: Wed Dec 26, 2012 10:15 pm
by JT4k
Definitely wishing you the best of luck on that and a speedy (8 sec) recovery :-)
Posted: Thu Dec 27, 2012 12:58 am
by Jersey90TQ
good luck and speedy recovery.
Posted: Thu Dec 27, 2012 2:08 am
by HeartlessNomad12
Best of luck with the back, having had to go under the knife for a herniated disk i feel for you. Dont be frustrated by the lack of mobility and pain at first, its a part of the game. Focus on the rehab, these people know what they are doing and want nothing more than to get you the fawk out there as soon as they can.
BE PATIENT!!
DON'T GET FRUSTRATED!!
BE PATIENT!!
Posted: Thu Dec 27, 2012 3:09 am
by MikkiJayne
Hope it all goes well
Posted: Thu Dec 27, 2012 9:56 am
by HT Motorsport
Hey Aaron, Looking good.
Dont forget to add an adjustable clutch pedal stop so you dont over travel your clutch. BTDT
H
Posted: Thu Dec 27, 2012 10:05 am
by speeding-g60
timmmy wrote:Hey Aaron, Looking good.
H
thanks H, for the remind. and i am on it, its in my mind. i cant do anything towards that until i have the actual motor in with the clutch assembly on it, to know where the travel needs to stop. but its on my to-do list.
Posted: Thu Dec 27, 2012 10:32 am
by nismo
So Aaron,
How do you know where to set the stop? I'm assuming its by feel?
Eric
Posted: Thu Dec 27, 2012 10:37 am
by speeding-g60
i set the old one up by feel, yes. there is a point in the pedal travel that you can "feel" that let me know it was fully pressed in, and pushing further was doing nothing.
maybe it is hard to explain.
Posted: Thu Dec 27, 2012 11:23 am
by Audilard
Aaron, good luck with the surgery and here's to a speedy recovery! Loving the progress on the car!
Posted: Thu Dec 27, 2012 12:24 pm
by HT Motorsport
Requires 2 people
Put car in gear and sit in seat. Have helper push on car against gear. Then slowly depress clutch until car begins to move and hold pedal there. Have helper come measure position. Then build stop with min 1/2" adjustment each way from that point. Then repeat with stop in place and adjust to about 1/4-1/2" pedal travel below creep point
Posted: Thu Dec 27, 2012 8:19 pm
by speeding-g60
thanks H. will do that in March sometime i guess
that will be great if it can improve my 60' time. because honestly i felt as if there was a quick spot on my release before it caught up and actually released. if i am making sense. it was really more pronounced with the launch valve setup in place, made it more obvious.
and my final work on the car, for now til awhile, and to end out 2012: finished up the brake lines, from the rear MC to the staging brake, to the rear line. just have to tighten all the front fittings from the motor side of the firewall to the SS lines, then bleed brakes. i suppose i could do all that in les than an hour, but i dont wanna.
and its final, break time for physical work on the car. surgery in T-minus-12 hours.
and i will make a long list of To-Do items, i already have a fair amount of ideas, just need to jot them down.
and also a long list of To-Buy items, like AWIC core and other much needed stuff.
and i had to go get a recliner chair from Rent-A-Center today, as i guess i will become best friends with one here for the next few weeks for sure they tell me. 8 weeks minimum no work, car work, bending, twisting, lifting>5lb. imma go CRAZY!!!! wonder how many times i can get banned from VWKotex? LOLz.
Re: Aarons Drag CQ: 12-27 brakes done, now for hiatus.
Posted: Thu Dec 27, 2012 8:43 pm
Good luck on the table!
Posted: Thu Dec 27, 2012 9:35 pm
by nismo
speeding-g60 wrote:wonder how many times i can get banned from VWKotex? LOLz.
Is there a number that goes that high?
I hope all goes well and you do as well in recovery as you do building cars! :woowoo:
Eric
Posted: Fri Dec 28, 2012 8:28 am
by Dr.Strangelove
The car looks great. Take your time to thoroughly recover and you'll be good as new. Good luck on all fronts (or backs?)!
Posted: Fri Dec 28, 2012 8:56 am
by PRA4WX
speeding-g60 wrote:thanks H. will do that in March sometime i guess
I chuckled at the "how many times I can get banned" comment.
Good luck.
Posted: Fri Dec 28, 2012 10:54 am
by quattro87
:stupid: Too funny, but all kidding aside I wish you the best of luck on the surgery. I don't envy you. Hang in there Aaron
Posted: Sat Dec 29, 2012 8:06 am
by speeding-g60
thanks guys. all is good so far. not even 24 hrs later.
it hurts of course, but what is going to kill me are the restrictions of mobility for 8 weeks. THAT is gonna be the hard part for me. and that 8 weeks was minimum!
tomorrow at 10:30 am i get to take the bandage off and see the incision. interested about that.
Posted: Sun Dec 30, 2012 9:39 am
by my2000apb
hang in there, its never fun but recover / therapy as they tell you and youll be fresh again in no time
Posted: Sun Dec 30, 2012 9:48 am
by speeding-g60
thanks for the support!
one name down, three to go. :slap:
so much to do on the car. and all i get ta do is lay here.... no hot tub, nothing.
Posted: Sun Dec 30, 2012 7:31 pm
by ChrisAudi80
Aaron, would one of these help you?
http://www.youtube.com/watch?v=Fh6z5BW_meE" onclick="window.open(this.href);return false;
Posted: Mon Dec 31, 2012 1:48 am
by zarati
mr_aj_johnson wrote:I really dig that fuse panel, any idea where you got it?
In pretty sure West Marine Carries that same unit. At least they did a few years ago. Check the one here in Spokane while you are waiting for your 3rd addition.
