Tim's '86 BLAZE 4kq EPIC PROGESS!!!!
Re: Tim's '86 BLAZE 4kq uploading pics +update
more
ebrake cable clips.jpg (977.54 KiB) Viewed 28727 times
brake line grommets.jpg (1.54 MiB) Viewed 28727 times
brake line correct.jpg (938.36 KiB) Viewed 28727 times
MORE!
Nothing too interesting here other than im running a ’91 200 20vtq brake master cylinder. The port arrangement is a bit different than the 4kq, but as I was making all new lines, it was a non-issue.
Pics!
plumbing new brake lines.jpg (1.37 MiB) Viewed 28727 times
handbrake hardline to new T and ind. rears.jpg (1.75 MiB) Viewed 28727 times
new rear pass. hardline.jpg (1.7 MiB) Viewed 28727 times
Note: the hardline coming down and out of the trans tunnel. That’s from the hydraulic handbrake mounted near the shifter!!!
All the rear lines are done, flared, attached and with new clips and softlines! Wooot!
all new hard and softlines with clips.jpg (1.92 MiB) Viewed 28727 times
all new hard and softlines with clips2.jpg (1.8 MiB) Viewed 28727 times
MORE!!
Here is the hydraulic Comp-Brake vertical handbrake inplace with the b5 s4 shifter box. It’s nice and close to the steering wheel and shifter.
handbrake and new shifter.jpg (1.63 MiB) Viewed 28727 times
handbrake mounted next to new shifter.jpg (1.49 MiB) Viewed 28727 times
Hardlines coming through firewall and rearward on trans. tunnel
handbrake hardline from MC.jpg (1.23 MiB) Viewed 28727 times
handbrake hardline from MC along tunnel.jpg (1.31 MiB) Viewed 28727 times
MORE!!
Fenders got their major dose of bondo smoothing, I just need to do one more skim on a few spots and they will be ready for paint!
more bondoage.jpg (1.72 MiB) Viewed 28726 times
more bondoage 2.jpg (1.35 MiB) Viewed 28726 times
more
drv fender vent.jpg (1.42 MiB) Viewed 28726 times
drv fender vent detail.jpg (1.87 MiB) Viewed 28726 times
pass fender vent.jpg (1.4 MiB) Viewed 28726 times
pass fender vent detail.jpg (1.7 MiB) Viewed 28726 times
UPDATE!!!
Getting down to the wire! Haha pun
There’s not too much left, wiring, driveshaft install, rework the undertray a little bit, etc
Wiring to go through, ugh
wiring to sort through.jpg (1.61 MiB) Viewed 28725 times
Time to take a break from mechanicals and get it to paint!!!
Here’s a pic of the engine bay just prior to wrapping it all up
most recent bay shot.jpg (1.73 MiB) Viewed 28725 times
All taped off awaiting paint.
engine bay all sealed up for paint protection.jpg (1.81 MiB) Viewed 28725 times
paint prep.jpg (1.15 MiB) Viewed 28725 times
Garage prepped for sanding, sanding, sanding then PAINT!!!!
needs paint.jpg (1.85 MiB) Viewed 28725 times
That’s all and caught up for now! Time to get back to work!!!
Re: Tim's '86 BLAZE 4kq EPIC PROGESS!!!!
for sale ad coming soon! to a swapmeet forum near you!!!
ermahgawd those wires
AngryTaco wrote:ermahgawd those wires
whatchou talkin bout!!!
I thought the wiring on my 4k 20vt was bad. That right there is nuts
AngryTaco wrote:I thought the wiring on my 4k 20vt was bad. That right there is nuts
youre crazy
a vems 4 cyl intergration ito a 4kq isn't bad!!!
I finally have some axle spacer material coming.
gotta pull the driveshaft and get it balanced.
finish up a fuel hardline
and ill guess ill dig into the last of the prep for paint at the beginning of next week
progress shall commence, I cant be going another winter without some Turbo Quattro fun!!!!!!!!!!
Its a good thing you bought that stuff from me. I was going to make a bom.....er soda can holder out of it
