Derracudas zermatt 20vt,6spd, 351awhp - July 4th drive vid
djapothecary
just curious, and you may have said it well before hand, but how the f*** did you get the head that clean?!
I'm guessing sandblasting . . .
if so I'll just return to my cement patio with wire brush and degreaser . . .
Otherwise certainly more than a comendable project! it's re-igniting my love for my first 4000 and just causing me to eye the one down the street more and more.
Keep up the good work, and p'rhaps someday my ur-quat will gairner such high praises!
peace on it
dj apothecary
peace on it
dj apothecary
90_Koop
derracuda
djapothecary wrote:just curious, and you may have said it well before hand, but how the f*** did you get the head that clean?!
Othe,rwise certainly more than a comendable project! it's re-igniting my love for my first 4000 and just causing me to eye the one down the street more and more.
yes, the head was bead blasted by the machine shop. i'm not quite sure what medium they use, but it works
and yeah, i love the 4kq's. simple, good looking, distinctive lines.
90 koop, i'll be keeping an eye out for the check, i got the subframe and suspension dropped yesterday 8)
quattrostyle
Audicted2quattro
Audicted2quattro
derracuda
Evansville IN to be exact?
derracuda
Clouse
derracuda
derracuda
ahhh, two weeks are finally over
first thing's first, i had to bring one of my A8 rims down since this car is 5x112 now and see if a 235/40/17 would even remotely fit......
slight touchy touchy on the rear inner tie rod, but that's fixed with 2-3mm spacer
more clearance here than with my old 7.5" ET35 and 215's 8)
the fronts will fit too, but i need to rotate the steering arm a tad. otherwise, i'm pleased and will be looking for a couple more A8 rims and then ordering up some new 235/40/17 kumho ecsta SPT's 8)
this is how the car sits with 200 20v rear springs in the front, and 5ks rear springs in the rear..... high
derracuda
- ralleyquattro
What size and offset are the A8 rims? Thanks!
derracuda
ok, got some more stuff put on yesterday, the IM is bolted on for good, the knock sensors are in and torque'd, spark plugs, the remaining 5 exhaust manifold studs came in and made their way home, some water temp sensors, the turbo, etc....
hey sparky 8)
i grabbed the waterneck off my 90q parts car and gave it a quick polish, not to bad for not even sanding it down or anything...
coming together nicely
also, i was going to put the wastegate bellow on and went... hmm, this is pretty ugly
so i cleaned it up a tad and polished the ribs. it'll look sweet when the heat makes it change colors
the turbo is bolted on, the lines are cleaned but need to be installed, and the compressor housing need to come off as well as the wastegate cap for cleaning and then put them back. some final wiring in the engine bay, then mount the alt, front snubber, radiator, P/S pump, IC and plumbing, and then i can put a little focus on the wires that are important to making it run
hey sparky 8)
s2 on the way
it'd be sweet if the wastegate was powdercoated black..........with a red turbo housing,,,,wait, that would be biting rj with the housing.....
but the turbo side needs to be matching since all else is so pretty and perfect....
would the downpipe and headers take to powdercoating and hold with all the heat?
looks great.......
looks great.......
