Page 16 of 82
Re: AMD's 91 200q Project
Posted: Fri Jun 10, 2011 8:44 am
by amd is the best
Thinking about giving E85 a try. What do you guys think? 870cc's and an 044 enough for 20psi?
Posted: Fri Jun 10, 2011 8:46 am
ya but you are going to want 30psi on E85... you'll probably want 1000's for that or turn up the fuel pressure on the 870's if you can.
Posted: Fri Jun 10, 2011 8:58 am
by amd is the best
But 30psi will pretzel the rods probably.
Posted: Fri Jun 10, 2011 11:11 am
by WOMBAT
You have E85 in NY???
Posted: Fri Jun 10, 2011 11:26 am
by apavlov13
Yesss we do!
Posted: Fri Jun 10, 2011 1:15 pm
oh, I figured you meant when you have a built bottom end. I don't see any advantage to E85 whatsoever unless you want to push the limits of pump gas and 20 psi is definitely not pushing the limits.
Posted: Sat Jun 11, 2011 12:51 am
by amd is the best
200 is now tuned to 24 psi on E85 and is LOVING it! Injectors hit 88% duty cycle, so there isn't much room left in them however it's also as far as I want to push the stock engine.
Link to video
Durring this video, we ran the Dynolicious App on my buddies iPhone and here are the results:
60': 1.88 sec @ 37.7 MPH
330': 5.01 sec @ 72.6 MPH
1/8 mi: 7.64 sec @ 94.6 MPH
1000': 9.91 sec @ 106.9 MPH
1/4 mi: 11.85 sec @ 116.0 MPH
Posted: Sat Jun 11, 2011 2:33 am
by ChrisAudi80
NICE!
Posted: Sat Jun 11, 2011 7:30 am
by amd is the best
Thing feels absolutely ridiculous.
Posted: Sat Jun 11, 2011 7:51 am
by ChrisAudi80
I liked the tire chirp. Means you are putting down power
Posted: Sat Jun 11, 2011 7:53 am
by TorqAddict
Nick, I think I've said so before but I flat out LOVE your car......nicest 200 I know of PERIOD.
Well Done!
Posted: Sat Jun 11, 2011 8:14 am
by WOMBAT
Damn.
Posted: Sat Jun 11, 2011 9:03 am
by amd is the best
ChrisAudi80 wrote:I liked the tire chirp. Means you are putting down power
The surface is concrete so it might be a bit more slippery? Either way, I like to hear some tire noise too :)
TorqAddict wrote:Nick, I think I've said so before but I flat out LOVE your car......nicest 200 I know of PERIOD.
Well Done!
Thank you Jeff! I really appreciate the kind words!
Posted: Sat Jun 11, 2011 9:10 am
by Colin2750
Damn you shift like a boss.
Posted: Sat Jun 11, 2011 9:15 am
by JonathanL
*clapping*
hows dynolicous working for you?, my buddy said he loaded it and it was glitchy, although I have heard it is rather accurate
you going to waterfest?
Posted: Sat Jun 11, 2011 9:22 am
by amd is the best
Colin2750 wrote:Damn you shift like a boss.
Thanks man! First gear is quick in this thing so I've got to shift like a pro. This was a flawless run, perfect amount of wheel spin, didn't hit the rev limiter (@ 7500rpm) but you can see my CEL come on in 1st/2nd gear which is set to come on at 7,300rpm. Good times! I need to get this thing to the track to confirm the times here.
JonathanL wrote:*clapping*
Dynolicious seems to work pretty well. I ran it back in my S4 and it seemed spot on then (I can compare it to actual runs at the track). It's important that you set the weight in correctly otherwise it'll be off. If you watch my video from the time I launch @4 seconds to the time that my buddy says "good" @16 seconds it's 12 seconds however he said good after the iPhone said the run was done. The MPH seems to match the speedometer pretty well too.
When is waterfest?
Posted: Sat Jun 11, 2011 9:33 am
by JonathanL
NIck, WF is July 16 and 17. last year we all went down friday night which is the 15th.
There was a serious lack of old audis there. I saw three coupe quattros and two 80/90 cars all weekend (one of which was sonaxevos) :drool: I dont think I saw more than two or three type 44s either, yours should be there basically :P
Posted: Sat Jun 11, 2011 9:37 am
by amd is the best
Damn, I work that weekend and leave for Myrtle beach on that monday so can't get any more time off. I've never made it down to waterfest. I've heard it's a bit sketchy though.
Posted: Sat Jun 11, 2011 10:19 am
by Mk4 30R
And a few of mine on it's journey to NY:
[/quote]
that was the scariest ride home ive ever had.
Posted: Sat Jun 11, 2011 10:27 am
damn dude, thats sick (the vid). Congrats on pushing the bottom end to its limit :D I really need meth to push mine harder in the heat here.
Posted: Sat Jun 11, 2011 12:14 pm
by amd is the best
loxxrider wrote:damn dude, thats sick (the vid). Congrats on pushing the bottom end to its limit :D I really need meth to push mine harder in the heat here.
Thanks man! It's a beast.
After a long pull like that it billows a cloud of oil smoke though. I thought I blew it up although lambda was .77. I was like wtf!! Then it cleared right up. I think I'm getting some blow by again with the boost a bit higher.
Legit catch can on the to do list.
Posted: Sat Jun 11, 2011 6:35 pm
by ChrisAudi80
Is the local 5-0 already on to ya? :)
Posted: Sun Jun 12, 2011 7:14 pm
by EDIGREG
Nice Nick!! How much timing did you add? I'd love to see a comparison of the timing maps. I can't wait to get some FIC1600's in and get e85 set up.
Are you currently recircing PCV to the intake?
Posted: Sun Jun 12, 2011 7:17 pm
Yeah... I'm also curious to see your old timing map to compare it to my current.
Posted: Mon Jun 13, 2011 5:29 pm
by amd is the best
ChrisAudi80 wrote:Is the local 5-0 already on to ya? :)
Not me, lol. They pulled my father over driving the 200 for "modified exhaust."
EDIGREG wrote:Nice Nick!! How much timing did you add? I'd love to see a comparison of the timing maps. I can't wait to get some FIC1600's in and get e85 set up.
Thanks ED! I only added a few degrees of timing because as you guys know I am still on the stock intercooler. What I did do though is almost completely turned off the IAT related timing retard. So realistically I am using E85 as a half-ass fix for a lack of intercooler, lol. It's working good though.
My injectors hit 88% duty cycle but I am still on a 3bar regulator. If I drop a 7A regulator in I'd be good for 30psi of boost + on E85.
I also did a compression check for the first time EVER since owning the car, here were the results:
Cyl 1: 190
Cyl 2: 185
Cyl 3: 180
Cyl 4: 175
Cyl 5: 200
Does this seem normal/withing range? Engine was to temp and all of these were "dry" tests.
