Tacos 4KTQ I0vt Swap: The Red Baron - buying parts again
Re: Taco's 4KTQ 20vt Swap: Project Red Baron
I took 2 front A-arms, reversed sides, and the sway bar bolted right up
Parents made me build a cabinet right in the middle of my fab work
Mounting up the FWD sway bar to the front sub-frame
Think I'm going to fab the center mounts up behind the tierods
Derracuda
Post by Derracuda »
just FYI, if you put the sway bar there in the rear, with those endlinks, the top portion of the endlink where it attaches to the swaybar will rub the axle. It's location relevant to the front is different due to different ball joint locations. You need the other more S shaped bracket (can't remember which ones have it), or, weld a solid chunk(say 1.5x1.5x1.5") of Angle iron on the back of the control arm to move it rearward. BTDT.
Gotcha! The s brackets are on my FWD sway bar. Ill switch em and see how it mounts up
So I threw those S brackets on the rear bar but now it seems the clearance is a little off. It might just be me but it seems the bar is awfully close now to where the sub frame bolts go.
I guess, worse case you could weld on some brackets like I did with mine. Either way, good progress man.
Scored a set of Fuchs! Should have the set sometime after next week! Gonna clean them up and powdercoat them white!
Did the spring perches today. Cut the 5000 perches off and fabbed up the 4000 stuff. Just got to weld it up on Monday
I welded up the shock perch on one of the struts today. I'm going to wait on the other one as the local JY just got in a 5000. If I can get a complete strut with hub, I'm going to use that one so I don't have to buy a hub and wheel bearing. Should save me money in the long run as a hub is about $30-40 and the bearing is about $80. Only $17 for a complete strut where I go :)
Also began pulling 5th gear apart. WHAT A PITA TO GET THE BOLT UNDONE THAT SCREWS INTO THE MAIN SHAFT!!!!!!
Didnt realize I wasn't supposed to pull off the synchro hub....oooops now I gotta put the hollow keys and spring wire back in place :frustrated:
Had to use a 5ft exhaust pipe to break loose the main shaft bolt holding the locker cover onto the main shaft
MY FRONT STRUTS ARE DONE!!!! YAY!!!!!! Welded up the final shock tower perch today!
This came off the brake rotor of the strut I had to grab in the JY. It used to belong to a brake rotor.......
rs4tech
Post by rs4tech »
Home made wheel spacers :grin:
Thats exactly what I was thinking lol
5th gear has been removed
Fuchs arrived today! Probably gonna get them powdercoated white within a month or so. Local shop said they'd do the set with sandblasting for $150.
Currently deciding between tire sizes. It's a toss-up between 205/60s or 215/60s. If someone can confirm that 215s will fit without rubbing, then I'm getting those.
Trimmed out the 5000 harness last night. Would someone be kind enough to identify the components in the pictures and tell me what I need and don't need? I will be running my digital trip odometer cluster as well so I will want to wire that up as well
Also, do I need to keep this in 1 piece?
rs4tech
Post by rs4tech »
Good progress, I will be curious to see how much of the harness you have to cut out...
New Starter Cable
Red Harness is in :-)
Fusebox before splicing into it
Used a pin out of an old connector
Pin is being inserted into the upper right pin port
Ta-Da!
Boom....clean factory look
Idle Stabilizer Controller fits in nicely with the other relays
Time for new Transmission mounts!!
No more stock head!
Headstuds and MLS headgasket!
Get it done man!
lookign great!!!!
evilandonehalf13
Post by evilandonehalf13 »
wow i am impressed this is looking terrific. great progress that car is going to scream. great color too.
so by changing your spring perches you can fit t44 5ktq springs>?
40v4kq
Post by 40v4kq »
my2000apb wrote:so by changing your spring perches you can fit t44 5ktq springs>?
He did just the opposite. Fitted 4kq spring perches to the 5ktq strut housing so the 4kq springs will fit them for a nice clean 5 lug swap. Same thing that derracuda has done a couple times and the same as extreme90path.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
evilandonehalf13 wrote:wow i am impressed this is looking terrific. great progress that car is going to scream. great color too.
Thanks man! The end is in sight! I can't wait to see how this thing runs and handles!
