Nick's 1991 200q Project - QUAT44RO
- amd is the best
Re: AMD's 91 200q Project
Just picked up a set of 7a cams finally. Does anyone have a good write up for a cam swap?
Its super easy. You don't even need to remove the timing belt. just loosen the caps evenly aka a little at a time then you can slip the tbelt off. then put new cam in while making sure the dizzy is still timed right and slip the timing belt back on. then tighten the caps down EVENLY to 11 ft lb and wait half hour to an hour to start it up. Wrote this from my phone so sorry for the crappiness .
- amd is the best
Thanks for the info Chris! What's the deal with waiting a half an hour?
Lifters need to bleed down.
- amd is the best
Makes perfect sense. Thanks!
death 4kqt
cam swap is cake, and will make your cars growl turn to more of a howl.
yep, it should sound a bit more like mine Nick
I turn the engine over by hand a couple of times by hand just to be sure
- amd is the best
Correct me if I'm wrong, but wouldn't the 7A's have a smaller base circle needing the lifters to actually fill up more and not bleed down?
Side note, what do you guys think about having the 7A's reground?
They decompress when you take the cam out. You have to compress them down when inserting the cam and this means they have to bleed down afterwards I guess.
I think having them reground would be sweet, but I don't know much about what specs make for a nice cam and how the 7a's would lend themselves to that profile.
death 4kqt
i'd say just run them, they will give you a noticeable increase. If you want to get something real crazy down the road, look into something like CATS.
- amd is the best
death 4kqt wrote:[/quote]
i'd say just run them, they will give you a noticeable increase. If you want to get something real crazy down the road, look into something like CATS.[/quote]
I'm thinking that's probably the route I'll end up going although if I'm not mistaken, the Cat cams that still utilize the hydraulic lifters are regrinds. That led me to thinking about just having my cams ground to their specs for $120 a cam.
http://www.034motorsport.com/engine-com ... 21695.html (the first four are "OEM Regrind")
interesting, I didn't realize those were OEM regrinds. Where does it only cost $120/cam? From CAT or somewhere else?
- amd is the best
EDIGREG wrote:interesting, I didn't realize those were OEM regrinds. Where does it only cost $120/cam? From CAT or somewhere else?
I got a few quotes from companies that do custom cam regrinds. The $120 per cam quote was from Schneider Racing Cams.
^^^ definitely not from CAT. I heard discussion of this before however. Someone had a shop that would do it... very slick idea. I wish I wanted profiles that the stock cams could be ground to :/
- amd is the best
You and your crazy plans! LOL. I am clueless when it comes to cams. Which profile of the "OEM" grinds would be best?
I'm clueless too, but to clarify you do want more top end right?
- amd is the best
Yes sir. And most importantly, a lopey idle! LOL. I'm not sure how much my .63 housing is going to hurt me either...
Well you definitely wont get much lope from a stock 7a cam, and probably not from a regular re-grind. Usually seems like the lope only comes on the solid grinds. However, you can induce an artificial cam lope on a switch if you write a second map with a really rich idle area for the car lol... ask me know I know
JonathanL
I thought I heard the 7a cams were a nice upgrade to 7500 rpms big turbo and all. Any revs higher than that needs head work anyway
- amd is the best
That's true. I had a dyno graph somewhere but can't seem to find it. I want to say that the 7A's made 40ish awhp more up top on a big turbo setup.
FYI mine never felt like it was dropping off above 7500.
- amd is the best
I've seen quite a few different combinations of stock cams and 7a's. Chris, I know you run both the 7a intake and exhaust cams but have you done any research in using them in combination with the stock cams? I am also seeing that there are different cam gears?
I have run AAN intake/7A exhaust and now both 7A. Not a huge difference between the two setups but you get more top end using both 7A. You will lose a bit of torque in lower RPMs, but it's worth the gains IMO. You gain more than you lose
Everything is a compromise.
Everything is a compromise.Ed
Yeah, I can't really comment on that other than I was happy with my top end. I have the Autotech cam gear. It works well with the 3b. Others can't use it due to AAN cam sensor I think.
