Page 25 of 28
Re: Pops' 1997 S6 2.5L Stroker - RESURRECTION BEGINS
Posted: Tue Jan 08, 2013 5:02 am
Didn't get anything yet
Posted: Tue Jan 08, 2013 10:07 am
Posted: Tue Jan 08, 2013 10:29 am
by my2000apb
meaty ringlands
Posted: Wed Jan 09, 2013 6:55 am
Regular or stronger wrist pins?
Posted: Wed Jan 09, 2013 7:32 am
20mm... Which is standard I believe
Posted: Wed Jan 09, 2013 11:47 am
Those look great! 8500 and under will be fine with 20mm regular pins with these power goals. Long rods are a lot easier on pins/rod necks.
Posted: Wed Jan 09, 2013 12:06 pm
I figured that would be the case, I was just curious if anyone else had 'em
Posted: Fri Jan 11, 2013 1:34 pm
I think the last piece to this puzzle is redoing the oil and water feed/drain lines for the turbo. The old stuff worked but just wasn't too great looking
I see 034's header line kit, just not sure how placement compares to Hank's setup. Also looking to not dick around. Messing with this stuff can be fun, but there's something to be said for plug and play oil and water lines.
And yes... I'm pretty stoked about this rod ratio. Really curious how it revs compared to the 92.8/220mm setup.
Posted: Fri Jan 11, 2013 1:38 pm
It would come close without the valve, but with it, it needs extra length. I wish I would have known. It would have been super easy for us to make some on the stand.
Posted: Fri Jan 11, 2013 1:42 pm
well herp a derp.
Posted: Fri Jan 11, 2013 2:07 pm
by my2000apb
jsut make some lines sissy
Posted: Fri Jan 11, 2013 2:30 pm
:stupid:
You can also measure with a string and then order lines already made. It just costs a bit more that way, but is very convenient. Just make sure you take the fittings into account.
Posted: Fri Jan 11, 2013 3:00 pm
by UrSobsessed
my2000apb wrote:jsut make some lines sissy
This^.
You know you want to quality stuff to keep that snail lubricated and cool...
Posted: Fri Jan 11, 2013 3:14 pm
lol
Chris, where do you order lines from?
Posted: Fri Jan 11, 2013 3:23 pm
I get my stuff from racepartsolutions.com, but that is just because they are local for me. They have nice stuff, but it isn't the absolutely cheapest out there. I'm sure there are plenty of other options, but I like to support my local businesses.
Posted: Fri Jan 11, 2013 3:54 pm
by my2000apb
UrSobsessed wrote:my2000apb wrote:jsut make some lines sissy
This^.
um what
Posted: Fri Jan 11, 2013 5:02 pm
by EDIGREG
Just go on summit and order the AN hose and fittings you need. The flanges you can get from 034/Marc/Hank/etc.
-4 oil feed line (I got a pre-made one from paragon iirc)
-8 for the water lines
-10 for the oil drain
oil drain flanges for turbo and block
oil feed flange for block
metric to AN adapter fittings for the water lines (turbo side)
i assume you already have the oil restrictor
Posted: Fri Jan 11, 2013 5:20 pm
Problem is Comp uses NPT fittings (yes I realize a nice little adapter will do).
Comp oil in is -3 NPT, oil out is 1/2" NPT, water is 3/8" NPT
Posted: Fri Jan 11, 2013 5:28 pm
by EDIGREG
ok well it seems like you have all the info you need to start buying fittings
Posted: Fri Jan 11, 2013 7:22 pm
by ralleyquattro
chaloux wrote:lol
034 does make them unterminated, I bought them that way to fit them myself.
Posted: Fri Jan 11, 2013 10:46 pm
But what I'd like to do is order lines that are done
Audi fittings on one side, Comp on the other. I just need some measurements I guess.
Posted: Sun Jan 13, 2013 10:01 pm
by EDIGREG
The only thing you need to do differently than a "kit" is cut the AN hose to length and put the hose ends on the hose. Custom will always be a better fit and better looking IMO.
I'm bored so here's a parts list:
Water lines2x 3/8"NPT to -8AN adapter:
http://www.summitracing.com/parts/sum-220846/overview/1x -8AN 45* hose end (water return):
http://www.summitracing.com/parts/ear-8 ... /overview/
1x -8AN 90* hose end (water feed):
2x copper crush washers for the NPT side of the water line adapters
4-5' of -8AN hose
Oil lines1x 1/2"NPT to -10AN adapter:
http://www.summitracing.com/parts/sum-220047/overview/1x copper crush washer for NPT side of oil drain adapter
1x block oil drain flange to -10AN (034)
1x -10AN straight hose end (block side):
1x -10AN 45* hose end (turbo side):
1x block oil feed flange to -4AN (034)
1x 28" oil feed line (you can get these pre-made from various places). -4AN on the block side, and whatever your oil restrictor accepts on the turbo side
3-4' -10AN hose
Posted: Sun Jan 13, 2013 10:46 pm
by UrSobsessed
Ed's boredom = your benefit.
Now git'r dun!
Posted: Mon Jan 14, 2013 9:17 am
by my2000apb
chaloux wrote:But what I'd like to do is order lines that are done
so you're building a motor and cant make water lines lmao
Posted: Mon Jan 14, 2013 2:23 pm
by Katman
He has already made a kid, so now has no time for making water lines..?
