1986 Coupe GT: Fresh Exhaust
the german
Re: 1986 Coupe GT: Fresh Exhaust
Post by the german »
Nice! So jealous of the lift!
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
scubagli
Post by scubagli »
Pretty awesome.
You can store crap under the car too ;)
I really want a lift!
w00t!
When's the 07k/t/quattro swap going to happen?
PRY4SNO wrote:w00t!
I'm already looking for a 5spd 1.8t fwd passat parts car... TDI would be awesome but too much money
the german
97-99 passat or 98-99 A4 will get you the right engine (AEB)
I found a ton of info here when I was researching it: http://myweb.whitman.syr.edu/srotblat/swap/
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Well new fuel pump didn't fix the problem, time to dig deeper!
the german
Damn!
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german wrote:Damn!
Yeah, going to triple check for vacuum leaks. Going to figure out what injectors it has too (fine or coarse thread), and probably order up a new set. Then I guess I need to check the setup of the fuel distro/metering plate.
the german
Have you tried that extra set of injectors I pulled from the wrecking yard? They were in a plastic bag in the trunk
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german wrote:Have you tried that extra set of injectors I pulled from the wrecking yard? They were in a plastic bag in the trunk
Forgot about those, I'll give them a shot
Got a Bentley this morning, going to dig into troubleshooting more tonight.
In other news, I'm picking up a complete 7A swap from Chris (varia). Not as potent as the 1.8T swap, but much easier and a better soundtrack. Then there's always the possibility of a 7At in the future if I decide 160hp isn't enough for 1 wheel drive.
the german
woohoo!! I like that solution :)
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Classy!
ITBs down the road would make it sing.
