Its been a very long time since ive updated anything on a forum, but the car is basically done now, just need to tune it. Which im finding out is one of the hardest parts. A lot of the building/fab work is fairly easy to me ( it dosent look that professional but it works and i did it myself) but the tuning is a whole new area for me. and right off the bat im having some issues. I registered tunerstudio and megalogviewer and am using them to try to sort out the MSII a quick recap of the cars specs:
1.8 16v, stock rods AAN pistons
crappy ebay exhaust manifold ( found on craigslist hadnt seen one before and seller said it was made in sweden :/)
t3 60 trim from ford thunderbird
2.5" dp to 3" exhaust
LC-1
air to air front mount intercooler
HKS BOV
adjustable FPR
42lb ford injectors
7a throttle body with ford TPS mounted to it.
so the car with start with throttle but without it will just run for a few seconds and die. when i log it it looks like i have HUGE pulsewidths and then runs rich, although the LC-1 never seems to work right away but only registers after a little run time, butwhen it does it reads 11:1ish and thats after its been running and the PWs have come down a bit.
another issue i observed is that when looking a the ignition map with the car running and the screen setup so i can see both the display and the ignition table there is a discrepancy between the 2 numbers, the display was reading 18 and the table was reading 14... i thought they would be the same. the distributor has been set with the trigger wizard and adjustable timing light
i was going to upload some logs to see how crazy this motor is running but .msl extension's are not allowed
. holding the throttle steady the rpm/map/afr's are all over the place
here are some photos at least
