Page 33 of 49
Casey's 200 20v: Back from the shop! Intake/Radiator done!
Posted: Fri Jul 27, 2012 5:59 pm
by WOMBAT
TurboQuattro88 wrote:When am I going to see this parked outside in the IBM lot when I walk out in the morning at 7am?!
Oooo about that...
Left IBM in May and I'm now working at GMCR! Go to Wolfsgart on Sunday! Champlain valley fairgrounds
Re: Casey's 200 20v: Back from the shop! Intake/Radiator do
Posted: Fri Jul 27, 2012 7:57 pm
by TurboQuattro88
Ahhhh, that explains why I haven't seen you walking in for a few months now. I'll be at Wolfsgart though, definitely. I also request a ride in this monster.
Posted: Fri Jul 27, 2012 8:16 pm
by WOMBAT
Absolutely - we'll see how far I get this weekend
Posted: Mon Jul 30, 2012 5:03 pm
by WOMBAT
Hit a minor roadblock - one of the 4 stud locations for the wastegate on the exhaust manifold is not drilled in the correct spot. Not sure what I'll do to correct it yet
Posted: Mon Jul 30, 2012 5:08 pm
by WOMBAT
Posted: Mon Jul 30, 2012 5:09 pm
On that Manifold? Impossible!~!!!!
I can't wait to make you a proper one some day
Posted: Mon Jul 30, 2012 7:18 pm
by glibobbo21
mine was like that too, bent the stud a bit and it goes on...
Posted: Tue Jul 31, 2012 6:43 am
by WOMBAT
I wish... Would require remaking dp and intake plumbing at this point :(
It's off by a good 1/8".
Posted: Tue Jul 31, 2012 12:52 pm
by WOMBAT
ShavedQuattro wrote:On that Manifold? Impossible!~!!!!
Better believe when this one dies I'll be giving you a call 8)
Re: Casey's 200 20v: VEMS Startup Help Needed
Posted: Wed Aug 22, 2012 5:53 am
by WOMBAT
Ok, we're on the home stretch!
I need those with experience with standalone EMS to help me out. I have not put power to the car or the ECU yet. My battery is charged and ready to go though. What's the first step here?
I have downloaded and installed VEMStune on my laptop. I don't even know how to load a base tune...
...Help?
Posted: Wed Aug 22, 2012 5:57 am
by death 4kqt
i could stop by after work, maybe bring cort. I am sure you can handle it just fine, but if you want some extra eyes on it, the offer stands.
Posted: Wed Aug 22, 2012 6:21 am
So I believe your ECU should already have a base tune loaded in if you got it fresh from Marc and told him about your setup. If not, then we need to start somewhere else. I am just going to assume for now that a base tune is loaded. In that case, you just plug the VEMS into your computer via USB-serial cable (having a good one is most important in my experience) and turn the key to the run position. Open VEMSTune and the gauges should display assuming you installed the USB-serial drivers correctly. If not, then you may have to play with the connection settings and select the correct port for the adapter, etc.
If you can see the gauges, just try and start it! If it has the base tune from Marc, it should definitely start assuming all is right. If it doesn't start, then we will have to go from there based on your symptoms.
Posted: Wed Aug 22, 2012 7:44 am
by amd is the best
You have the same pump and injectors as me. You could probably load my map and be fine to drive around no problem. In boost might need some work as your turbo is larger.
Re: Casey's 200 20v: IT RUNS!!!WOOOO!!!!
Posted: Wed Aug 22, 2012 6:13 pm
by WOMBAT
Posted: Wed Aug 22, 2012 6:16 pm
by pilihp2
Nice!!! Super satisfying when that happens.
Posted: Wed Aug 22, 2012 6:22 pm
by WOMBAT
Holy eff it is satisfying... all the times I thought about selling it
Posted: Wed Aug 22, 2012 6:23 pm
by Viridia
WOMBAT wrote:Oooo about that...
Ha! Neat, I used to work for the company that builds most of GMCR's packaging machinery.
Posted: Wed Aug 22, 2012 6:26 pm
by WOMBAT
Right on! Out in NY perhaps?
Posted: Wed Aug 22, 2012 6:30 pm
by Viridia
WOMBAT wrote:Right on! Out in NY perhaps?
Yup! Left there and moved to Seattle in January to expand my job palate, though.
Posted: Wed Aug 22, 2012 8:22 pm
Awesome!
Posted: Wed Aug 22, 2012 8:37 pm
wooot
Posted: Wed Aug 22, 2012 8:48 pm
by Audilard
Very nice! I know how it feels when you get it going! Good work!
Posted: Wed Aug 22, 2012 9:27 pm
by tbar
YES!!! :-)
Posted: Thu Aug 23, 2012 2:04 am
by fasterthenrs2
:woowoo: :woowoo: :woowoo:
Posted: Thu Aug 23, 2012 4:43 am
by death 4kqt
nice!
