Page 37 of 57
600+whp 1990 90Q...custom exhaust mani, again
Posted: Sun Nov 27, 2011 9:10 pm
by Zerb
Exhaust needs to run down car, for the sake of my eardrums on the street and to run in the true street class if I want to at the track.
Re: 600+whp 1990 90Q...custom exhaust mani, again
Posted: Sun Nov 27, 2011 9:30 pm
by bdcoombs
that small straight between collector and first 90 i dont have.. also makes turbo sit alot lower.
unless you are looking for the extra height.
if you need more pics let me now.
Posted: Sun Nov 27, 2011 9:31 pm
by bdcoombs
dam i have same wheels..and your getting the 66 too, double damn i thought id have a leg up with that.
if you didn't order the wheels yet i have a dude u can call there and get a discount, just say you part of this mustang forum they sponser. worked for me..
Posted: Sun Nov 27, 2011 10:10 pm
I am on the 4th header in my urq! You get more inspiration on every one!
How come you 4 cylinder guys are against putting the turbo where the 5 cylinder guys do? It seems like you would cut a ton of length and weight off the header.. cuz that's why you swap in 4 hangers right? The weight
Re: 1990 4cyl20v 90q...DYNO 648hp 508tq
Posted: Mon Nov 28, 2011 12:51 am
by Volkcar
Jiggle_Billy wrote:The sound just isn't the same though....
:stupid:
Posted: Mon Nov 28, 2011 3:42 am
by fasterthenrs2
nice stuf congrats on a drags
Posted: Mon Nov 28, 2011 5:45 am
by Zerb
ShavedQuattro wrote:I am on the 4th header in my urq! You get more inspiration on every one!
Post a pic, I'm being lazy and dot want to search, lol. I assume you're talking about putting it nearer to the inner fender well.
In this case I want it there because I already cut the passenger floor out and made a tunnel above the passenger side Trans mount so that I can fit a 4" pipe right there. That way I can run the exhaust right over the tie rod, and right down that tunnel and down the car.
Posted: Mon Nov 28, 2011 6:46 am
by Zerb
the idea here is to shoot the pipe right down there....
that will avoid me trying to get a 4 inch pipe wrapped down and around the axle, 3 inch is fittable (and ive seen many do it on here) but 4", even if it WOULD fit...i like to make things easier then harder.
Posted: Mon Nov 28, 2011 7:25 am
by fasterthenrs2
will your hood close with turbo being that high
Posted: Mon Nov 28, 2011 7:39 am
by Zerb
i can fit my hand between the top of thet turbo and the hood at the moment.
i was a little worried about that for heat/expansion, but i guess we will see. any lower and id need to start smashing the frame rail to get the collector to clear. its tight, because if i then bring the collector in closer to the valve cover, and also lower, then youd be taking the turbo off just to take the valve cover off. no bueno.
Posted: Mon Nov 28, 2011 8:35 pm
by Zerb
valve cover clearance, tight but doable, especially because i did away with the valve cover studs and went to bolts. just need to make sure i can remove the thing if i need to without removing the freaking turbo, lol.
number 4 runner
the very start of the number three runner. you can see why i had to set it up the way i did. if i moved the collector further away from the motor, the runners would hit the frame rail as you see. if i were to move it up as well as out to clear the frame rail, then the turbo would hit the hood.
now with the hood clearance, i lied a bit....it clears, but i can't fit my hand in there, haha. I'm not sure what will happen with heat/expansion, but i guess we will have to see. the motor/trans mounts are solid so the motor doesn't move much at all. maybe when its all done i can pop the turbo flange off and see if i can machine off a wee bit on the top of the collector to bring the turbo down a bit and gain some hood clearance.
Posted: Mon Nov 28, 2011 8:44 pm
by bdcoombs
mine is all up on the frame rail as well.. looks good so far
i like the tunnel idea more and more.. i like your tin work hehe
Posted: Mon Nov 28, 2011 9:14 pm
by Zerb
Ya. It gets tight down there. Hopefully I'll get the number two runner done tomorrow night so I can make sure the intercooler pipe is going to fit in there too. Don't go stealing my firewall/tunnel cutting idea now!
Posted: Tue Nov 29, 2011 9:12 am
by my2000apb
check out my threads in my sig, the 16v aba 4kq jsut got a 4cyl tube mani built for it
and the cq vrt project has a bunch of exhaust tunnel pics
and i took a ton more thatll be up in my cq thread tonight and teh vr6 cooling thread i have going currently
Posted: Tue Nov 29, 2011 7:56 pm
by Zerb
i actually got it all sorted this evening.
ended up popping the turbo flange off and grinding down the collector at an angle that brought it further away from the head and lower into the bay. now i can close the hood and get my hand in there between the turbo and the hood with room to wiggle so it'll be mint.
thanks for the links though.
Posted: Thu Dec 01, 2011 7:15 pm
by Zerb
Posted: Thu Dec 01, 2011 7:56 pm
What are the specs of your wheels on the turbo you are running right now? I got a new snail on the way and I wanna compare notes with your setup.
Posted: Thu Dec 01, 2011 8:29 pm
by Zerb
its a precision 6765. t4 exhaust housing .81 a/r.
PT6765
Compressor Inducer 67mm
Exducer 87.5mm
Turbine Inducer 74mm
Exducer 65mm
over the winter i am going to get their new CEA '66' wheel put on the thing which they claim is good for 3-500rpm earlier spool and 40-70whp more. the STM "ricer" evo went high 8's with the thing so it makes a shitload of power.
do i NEED the extra HP and spool to run what i want, no....as aarons car has proved that you can go high 9's with 600whp at the weights we are at. BUT, for a few hundred bucks at this point in the cars lifetime, you aren't going to to get that sorta power spending that money elsewhere.
Posted: Thu Dec 01, 2011 9:01 pm
For sure. The PTE exchange programs rock.
The 94mm exducer on the HTA compressor makes me nervous coupled with the smallish 72.5mm 78 trim turbine.. I hope all that compressor can all fit past the turbine.
Posted: Fri Dec 02, 2011 6:22 pm
by Zerb
so, by a show of hands, who's gotten a 4" pipe successfully down the car, over the rear axle and out the back? i remember when i was first messing around with the exhaust on this car a 3" pipe seems tight over the axle, i feel as if a 4" may need some magic to fit.
Re: 600+whp 1990 90Q...4" out the back?
Posted: Fri Dec 02, 2011 8:54 pm
by bdcoombs
cant you exit right in front of the rear tire in true street?
Posted: Fri Dec 02, 2011 9:44 pm
by Zerb
im not exactly sure. the cars I've seen vw/audi wise....todd pavics' mk3 gti, timmy mullens mk3 gti vr6t and the USP s4 vr6t all had exhaust s exiting the rear of the car.
Posted: Fri Dec 02, 2011 10:00 pm
by bdcoombs
i tired to look it up but it seems nscra.com had changed and now doesnt have class listings and rules any more. there is a link for rules details but it just takes you back to nscra.com homepage, maybe they are in process of changing the site over.
used to be
http://www.nscra.com/truestreetim assuming its becuase of nopi now owning part of the nscra
Posted: Sat Dec 03, 2011 7:44 am
by easterneurocoupe
It shouldn't be too difficult if you make a small "tub" for the. Exhaust bend where it goes over the axle
Posted: Sat Dec 03, 2011 9:23 am
by Zerb
you mean cutting the floor and welding in a piece that will allow for more clearance over the axle?
at that point i may just oval the tubing a bit to get it to fit before i did that to be honest.
