Fuel rail injector extensions-convert 1.8T rail to fit 16V
vwnut8392
Post by vwnut8392 »
These are a little part me and my friend came up with to make converting a 16V VW engine to EFI a bit easier on the pocket. These are fuel injector extensions that allow any 1.8T fuel to fit on the original 16V VW intake manifold. This is a DIY part as you have to cut off one of the mounting points on the fuel rail, move it and weld it back on plus drill and tap you intake manifold to mount the rail to it. We have been using these for years on our cars with 0 problems. these extensions use the OEM bosch injector O rings as well. if your looking for a cheaper solution to buying an aftermarket fuel rail with an OEM look than this is the answer. These extensions work with both golf/jetta fuel rails and the audi A4/passat fuel rails. if you have any other questions feel free to ask me. im looking to get 15.00 an adapter or 60.00 for 4 and that includes shipping in the USA, for over seas shipping there will be additional shipping fee's.
Sorry for the bad pictures lol.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
jrocco88
Re: Fuel rail injector extensions-convert 1.8T rail to fit 1
Post by jrocco88 »
i would like to buy a set of the injector extensions from you for a 1.8t fuel rail! please get back with so we can make a deal
