UrS4 Under dash power posts, question
Posted: Tue Jul 29, 2014 4:14 pm
by Draky
Finishing the install on my radio system right now and I just realized I don't really know which posts to use... I pulled the covers at the driver's knees (pic below) and was told to use post 15 for ignition source. Is there a post I can use for illumination? The posts are numbered the following:
30, 30a, 58a, 75x, 15a, 75a,15
And almost forgot to mention, this is on a 92 UrS4
Thanks again for the help guys! You guys always ROCK!!
Re: UrS4 Under dash power posts, question
Posted: Tue Jul 29, 2014 5:26 pm
by morris400
I used 75x for my boost gauge install. Not sure if it helps but thats what i used. It works for the gauge light.
Posted: Tue Jul 29, 2014 5:46 pm
by Draky
So 75x gives your gauge light when you turn on the lights on the car?
Posted: Tue Jul 29, 2014 7:15 pm
by my2000apb
if you have a Bentley its easy to chase down the dimmer switch wire
Posted: Tue Jul 29, 2014 8:39 pm
by Draky
I do not have one.
Posted: Tue Jul 29, 2014 9:34 pm
by Draky
Anyone with a Bentley care to help me out? Just trying to verify post for illumination, think it may be the 75x.
Posted: Wed Jul 30, 2014 12:52 am
by scubadave
you know, you could always try probing that post and others with a test light or DVOM to see what it does when cycling the key, turning on the lights, playing with the dimmer ect.
Posted: Wed Jul 30, 2014 7:34 am
by EDIGREG
75x is switched 12v
Posted: Wed Jul 30, 2014 8:37 am
by dana
just start probing around with a multimeter and find something that switches on with the lights and drops voltage with the dimmer. Easy.
Posted: Wed Jul 30, 2014 8:53 am
by Draky
dana wrote:just start probing around with a multimeter and find something that switches on with the lights and drops voltage with the dimmer. Easy.
Problem is I recently moved and can't find my multimeter.
Posted: Wed Jul 30, 2014 10:35 am
by dana
bummer! I can't live without mine.
Posted: Wed Jul 30, 2014 6:04 pm
by morris400
Draky wrote:So 75x gives your gauge light when you turn on the lights on the car?
Yepers
Posted: Wed Jul 30, 2014 8:58 pm
by UrSobsessed
There should be a source in one of the wire harnesses for the stock HU. If you want it to operate with the head lights, and dim with the rheostat on the instrument cluster, then tap into the wires for the ashtray light. I tapped those for my boost gauge so it goes along with the dash lights.
Posted: Thu Jul 31, 2014 7:25 am
by EDIGREG
Yepers
No, 75x is switched 12v. If the ignition is on, it is hot.
Like Dace said, if you want it to turn on with the headlights and dim, ashtray is the easiest source
