Rebuilding a k24, cant get exhaust housing off!!!!
Posted: Sat Sep 20, 2014 2:21 pm
by Dutchbroracer
So Im rebuilding my k24 for smog purposes. I got the bolts holding the turbine housing loose. I can not for the life of me get the housing off. The nuts on the turbine housing hit in certain areas, I've read some guys continue to run them out and it helps separate the housing from the center section...anyone know any tricks?
Re: Rebuilding a k24, cant get exhaust housing off!!!!
Posted: Sat Sep 20, 2014 3:14 pm
hammer to jar it loose, then rotate to get the nuts off.
Posted: Sat Sep 20, 2014 3:42 pm
by scubagli
BFH and heat...
Posted: Sat Sep 20, 2014 6:39 pm
by Noisy Cricket
Oxyacetlyene torch, go around and around until it is orange, lift the turbo out of the housing.
Posted: Fri Sep 26, 2014 6:36 pm
by Dutchbroracer
Posted: Sat Sep 27, 2014 8:18 am
Knock sensors are a (cheap) kind of preventative maintenance.
Do it.
Posted: Sat Sep 27, 2014 12:43 pm
by All_Euro
Nice work on the rebuild.
Not sure if the knock sensors are the cause of your boost issues but considering how sensitive the sensors are and their need to be torqued to the block to an exact spec I'd suspect they aren't reading right. If you can log their voltage values you'll see how they're reading at lower boost levels... if the cracks are messing up the sensors then they should be off throughout. Or I guess you could loosen them a hair and see if that helps but, personally, I'd replace them - or at least put some duct tape over the cracks
