91 non-ethanol vs 93 with ethanol
Posted: Sat Nov 08, 2014 12:11 pm
by 88a5tq
Been meaning to ask about the advantages, if any, of running country fair's new 91 ethanol-free gas compared to their less expensive 93 octane gas? Anybody do testing with VEMS and its ability to resist detonation? My brain tells me that the 93 would take more volume but be more knock resistant...
Re: 91 non-ethanol vs 93 with ethanol
Posted: Sat Nov 08, 2014 4:36 pm
by Noisy Cricket
Run the 93. It's cheaper and has a higher octane rating.
The non-ethanol fuel is for to make money from the chemtrails crowd.
Posted: Sat Nov 08, 2014 5:18 pm
by 88a5tq
cool thanks. Been doing it right all along lol
Posted: Sat Nov 08, 2014 8:22 pm
by roortube
I run E0 in my small engines. I got tired of replacing carbs each season. I switched last year. So far so good...everything started right up this year.
Posted: Sat Nov 08, 2014 8:26 pm
by 88a5tq
Ya funny you mention carbs and diaphragms... my mower just needed a rebuild from the ethanol stretching them out. Glad it doesn't affect the old audis in the same manner
Posted: Sun Nov 09, 2014 1:41 am
by roortube
I don't mind that so much as the corrosion in the carb bits. Bowls floats and chambers hate ethanol even worse when the parts are tiny.
Posted: Sun Nov 09, 2014 6:57 am
by Noisy Cricket
That's all really weird... Ohio has been E10 since forever and I never have had to rebuild a mower or snowblower carb.
Posted: Sun Nov 09, 2014 12:53 pm
PA has been E10 for a long time. I prefer E0 in everything but its hard to come by. The ethonal in the gas has a habit of collecting water. If you drain the carb at the end of the season, you are normally good to go the next year.
Posted: Sun Nov 09, 2014 7:53 pm
by roortube
Most of my stuff lasted 2 or 3 years the first time around, then required eeplacement every year. I treat the gas and drain everyhing fo4 storage. I also keep stuff in climate control. Its only been ome year so far, but i used the same junk replacement parts this past time as before and everything has run well so far. Only change was E0.
Posted: Sun Nov 09, 2014 9:03 pm
Small engines and especially boats are the only thing worth using rec 90 or whatever (ethanol free) in. For any car that gets normal use, the E10 will not hurt anything.
Posted: Sun Nov 09, 2014 10:28 pm
From what I can ascertain, the biggest difference will be that the e10 content will change your AFR. What I've found says an E10 blend is to be set to a target value of 14.2:1.
At that point octane is octane and resistance to detonation is moar power... compensate for the ethanol and you're set to go!
Posted: Mon Nov 10, 2014 12:03 am
I personally think the biggest differences lie in the corrosiveness and especially the fact that it is hygroscopic.
