starting with some old housings.
cut off arm and cup for the spring
grind up body
and two strut housings await the spring perch/steering arm plates being made by Chris@Nubworks.
speeding-g60 wrote:So i have been getting many many questions about the coilovers i made, such as part numbers, where, what style, etc. i do not mind answering these questions for everyone, but maybe if i put down the EXACT part numbers i used here, everyone will know them. please, these are the only ones i have any experience with. while i truly do not mind helping out, this is what i did and it worked out for me. so i do not know about the other cars, etc, as i have no idea with them.
this should be stickied, as well. from what i understand, this method is roughly the same cost as a GC kit. you still have to weld on the rings with GC as well. but i like self-made stuff, a sense of "ownership" and accomplishment comes with doing it yourself.
the sleeves, perches, and tops i got from http://www.a1racing.com and the car i did was 1990 Coupe Quattro. i have done 90Q and also B3 80Q as well. they have a 55mm OD strut tube.
this is the tops i used: http://shop.a1racing.com/cok12470.aspx
this is the sleeves i used: http://shop.a1racing.com/cok12452-h.aspx
this is the perch i used: http://shop.a1racing.com/cok12460.aspx
dont forget the set screws for the perch: http://shop.a1racing.com/cok12485.aspx
next, being on a budget (sort of: this is funny if you know my project haha) i went to http://www.Summitracing.com for springs. QA1 is really inexpensive for springs, in some lengths and rates. i did 7" up front, but you will probably want to go 6" as mine does not go really low. and i went 8" in the back.
the front sleeves you need to cut down to fit onto the housing, they are long. the rears are fine as shipped.
i made a set of the rings that i had to weld to the tubes for the sleeves to sit on. i used a standard holesaw, and drill. the ID i made 54mm and cleaned it up with a die-grinder. the OD i made 76mm.
my spring rates are not for you, i can almost guarantee it. but i went 7" x 650 lb front and 8" x 900 lb rear. i have quite a bit of input from others here on what they used, but a general idea is 6" front and 8" rear. the rates is up to you, but most use 350-400 lb all round. mine may be just right for me as i do not run a 5cyl in the car, a lighter 4cyl is in there. i guess it really depends on your use, but mine is drag race only. period. ever.
when you weld the ring to the strut tube, it needs to be perfectly flat. and i only welded the bottom, so i did not have any obstruction in the way of the sleeve. the purpose is so that the sleeve has as much support as possible. no ring for the sleeve can lead to the sleeve splitting out on the weld of the old perch if it is not removed completely. remember this holds the whole weight of the suspension of the car on it.
i took a grinder, and wiped out the factory perches. set up my new rings, and welded them up.
here are some pictures. this should be all you need to get this job done.
the strut housing without the OEM perch.
the parts used. i also did all the subframe and control arm bushings at this time, as well.
so i drill, and start the outer ring.
then move to inner ring, so i can use the same pilot hole.
go back to the outer, and get it deep enough to not need the pilot hole anymore, and finish inner hole.
finish outer hole, and i have two rough perches.
clean out the bore to fit just so over the strut tubes, and clean up outsides as well.
set up the sleeve on the strut housing, so i make sure to get the perch flat all the way around for the sleeve.
weld it up, and viola, a coilover strut housing is made.
here is the completed look of the B3 setup i made. notice the front is a little different. this is because i made my own tie-rods for the front end, and did something a bit different. but doing the front just like the rears is fine.
here is the finished Coupe rear strut.
and the Coupe front strut setup. couple shots.
[/i]
speeding-g60 wrote:
also, look up take-up spring sleeve..... thats what i did.
here is a few different options on this page. but at $25 a pop for the spacer/sleeve thing and $25 for the take-up spring, its another $200 for the whole car.....
http://www.genesisshocks.com/shock_accessories.html" onclick="window.open(this.href);return false;
http://pitstopusa.com/b-4664-132093-hypercoils.html" onclick="window.open(this.href);return false;
http://pitstopusa.com/c-133219-springs- ... acers.html" onclick="window.open(this.href);return false;
http://www.speedwaymotors.com/AFCO-Take ... 24622.html" onclick="window.open(this.href);return false;
http://www.performancebodies.net/Produc ... gs&pid=768" onclick="window.open(this.href);return false;
speeding-g60 wrote:thanks for the addition! i only copied my pertinent info from the other thread.
but i am glad that you are able to offer your pieces here for sale to anyone that doesnt want to go the holesaw route. it does suck, it is time consuming and a pain in the arse!
do you, by chance, have a price per pair of your machined pieces? i am sure if they were offered when i first made mine i would have hit you up for them. some things are easier to buy than make unfortunately. and these rings may just have fallen into that category. after the initial DIY, i ended up making about 3 more sets for other people then gave up as it was time consuming..... and time is sometimes worth more than the $$$$.
I've been considering the KWs because of their larger valves and other improvements but if the arm does not offer more tire clearance that would be an issue.
said it took about 50 minutes per, and i told him the rest i can cut by hand LOL.
amd is the best wrote:Awesome thread!
Aaron, have you come up with some type of a solution to keep the insides of the front springs from annoyingly rubbing in the strut nuts? Mine squeak like crazy and it's a bit annoying.
SEStone wrote:amd is the best wrote:Awesome thread!
No issues hitting with B3 stuff. Are you using real 2.5" ID springs, or did you possibly get 60mm? Also, are you using the super cheap Summit ones, or a real Eibach/Hyperco/Swift spring? Better springs bow less when compressed and help avoid that.
amd is the best wrote:I have Eibachs in my coilover setup so I assume they are 2.5". Maybe T44/URS strut nuts are larger?
Judging from that picture, T44 nuts are larger.
