who owns AAN/3B swapped 4000's and whats your 1/4 mile times
Posted: Mon Jun 29, 2015 6:57 pm
by vwnut8392
im just curious to see how many guys here have swapped cars, whats done to them and what they tear down the quarter mile.
i got one pass out of my car last year and ran a whooping 13.6 spinning all 4 tires first and second gear.
here's a break down of my pass.
reaction time=.8791
60ft=2.4074
330ft=6.2145
1/8th mile ET=9.0371
1/8th mile mph=85.32
1000 ET=11.5968
1000 MPH=96.09
1/4 mile ET=13.6153
1/4 mile mph=108.72
the car is an 84 4000 so its lighter than the 85 to 87 cars. the mods listed are at the time of the pass.
engine
-swap from 93 S4
-7A cams
-metal head gasket
-ARP head stud kit
-ebay tubular manifold modified with T3 flange welded on
-ebay T3T04E turbo with .63 AR turbine housing/wheel and .50 AR compressor side
-1.9 BAR wastegate spring
-custom intake
-31X12X2.5 front mount intercooler
-forge motorsport splitter diverter valve
-full 3in turbo back exhaust with vibrant performance stealth muffler
-AC delete
-modified stock motronic with 034 varimap set at 3BAR with custom chips
-NG single mass flywheel
-clutchnet 6 puck solid hub clutch
-RS2 pressure plate
-custom engine, tranny and rear end mounts made from HDPE plastic
-tommis billet crank gear
suspension/wheels/tires/brakes
-H&R springs
-Bilsten sport shocks
-FWD coupe GT front sway bar modified to fit rear subframe
-HDPE plastic subframe bushings
-stock 4000 quattro wheels
-bridgestone blizzak winter tires
-cross drilled and slotted front rotors
-mintex brake pads the whole way around
Thats all i can remember off the top of my head. i think it should be faster than what it is looking at the single pass i got last year.
the only revisions for this year are....
-VEMS V3.8 ECU
-2.2 BAR wastegate spring
-unknown 15in wheels that are pretty light
-nitto NT01 tires on all 4 corners
lets see what you guys have and what sort of passes your making, im curious as to if my car has more in it than it lets on.
Re: who owns AAN/3B swapped 4000's and whats your 1/4 mile t
Posted: Mon Jun 29, 2015 10:14 pm
by paradox11235
If you're spinning the tires I'd say some good tires should make a solid difference. Not sure how wide you can go on that chassis...
Posted: Tue Jun 30, 2015 8:44 am
by mushasho
If you shave .6-.7 off you 60ft, you'll see better results.... I was running 13.3-13.4 on Rubi when she had your same turbo.
Posted: Wed Jul 01, 2015 11:33 am
by vwnut8392
paradox11235 wrote:If you're spinning the tires I'd say some good tires should make a solid difference. Not sure how wide you can go on that chassis...
I have nitto NT01's that are 205-50-15 this time around, the tires when i ran a year ago where 185-60-14 bridgestone blizzak's lol. great for traction in the snow, useless at the track hahaha!
mushasho wrote:If you shave .6-.7 off you 60ft, you'll see better results.... I was running 13.3-13.4 on Rubi when she had your same turbo.
thats what im hoping for with this other tire setup. i'd like to see high to mid 12's atleast. im already limited by hos much boost i can run at the moment because of my injectors. i have RS2 replica injectors in there at the moment but there's an 044 fuel pump feeding them with the stock 4 bar FPR. according to VEMS at 20 to 21 psi with an AFR of roughly 11.8 im at 87% duty cycle and i dont really want to push on them any harder. my next big investment for its like a set of 1200cc RC engineering injectors than stepping up to something like an ebay GT3582. i hope to dip into the low 11's/high 10's on the GT35.
Posted: Wed Jul 01, 2015 11:41 am
by mushasho
I've got a set of 1200cc FID's that'll get you where you need & then some... PM me here or on FB...
Here's a 13.4 run on your setup...
[youtube]http://www.youtube.com/watch?v=RdHmQbTWuN0[/youtube]
Posted: Wed Jul 01, 2015 12:44 pm
by vwnut8392
mushasho wrote:I've got a set of 1200cc FID's that'll get you where you need & then some... PM me here or on FB...
looks like a solid run! i wish i had video footage of my friends URS4 that used to run 11.2's consistantly. that picture i posted a while back of FB of the red URS that looked like it was going to do a backflip is my friends james's old car.
how much you want for those injectors?
Posted: Wed Jul 01, 2015 12:46 pm
by mushasho
yeah,... that's the red car from yesteryear... guess what color my car is... I hope to be as fast... talk about good ole fashion power huh...
PM me on those injectors...
Posted: Wed Jul 01, 2015 5:33 pm
by alxdgr8
I think your engine is showing plenty of power, it's just not getting to the ground. Definitely need more of a tire, and probably more practice if you've only done one pass.
Taco ran 13.63 @ 98.7 in his 20vt 4kq (I think with a K24 or K26, not with the volvo turbo he later ran). With your trap speed, you could definitely gain a lot with some traction.
My stock UrS4 ran 14.68 @ 95 (2.05 60'), so you can definitely see the weight advantage of the small chassis for a pretty close trap speed.
derracuda with a stock K24, chipped ECU 20v
Posted: Thu Jul 02, 2015 2:54 am
by vwnut8392
only one pass at the track but plenty of street racing in the car. its actually still undefeated on the street at the moment :lol:, no one ever see's quattro coming all they do is see it going. i'll be happy with a high to mid 12 second pass. i've been playing with a few of the online calculators and they estimate low to mid 12's in a perfect world.
