It started with this engine, picked up from a member- at least I think he's a pad member.
2.6L eurospec bottom end built up as a 20v NA engine.
I also had this on the shelf - left over from my days as a 200 20V avant owner; a rebuilt 20V head, also picked up from a member a few years back.
I pulled the 20v apart
Checked a few things out. Everything looked good, and since the engine was supposed to have about 30K miles on it, I was hoping for no surprises.
Since I was there, I spent a little time converting from rusty cast iron, to NEW cast aluminum block!
Then I started going the other way...
Swaintec coated VW 9A (16V NA) pistons
Yup, that should do...
tried a few things out..
I had a few iterations of accessories on there, originally thinking I could go with the 3b/7A style rigging...
Soon found that there were issues with the PS pump and the AAN intake. After trying several different things, including mounting the PS pump on the other side of the block, and making brackets to mount the pump lower to clear the AAN intake, I finally caved, and went full AAN serp belt...
... but the 2.6L South African block did not have one of the mounting points for the AAN accessory mount...
Also needed to deal with this issue
A little bracketing work took care of both...
I also needed to drill the block to mount the timing belt tensioner. One hole attempt apparently was a little off... resulting in a small heart attack as the drill punched out the other side!
I looked in the hole, and didn't see any pistons, so figured I was OK... Plugged it up, and tried again!
Hope it holds! Seems sketchy with just the 6mm bolts...
Next issue was this:
After some head scratching, etc, I came up with a solution:
Also seen:
the nipple for the self bleed line to the coolant reservoir.
The drilled and tapped multi-fuction temp sender body, to hold a regular temp sender
Guess that's all for now.
If you see anything I F'd up, please don't tell me!
Nat
