07k longitudinal swap
Posted: Thu Mar 10, 2016 9:16 pm
New on here, been lurking for a while. Deciding on swap on my b5. Right now its between an 07k and a 3.6 vr6. Leaning towards an 07k just because its cheaper. And fits better lighter more support etc.
Need to decide on which exact 07k to get. Couple of questions. My line of thinking is based on 1.8t built on oem parts and aftermrket rods.
Target: 450awhp 93 and 550awhp meth
(Questions are random and just type as i go along)
1. At what power does the cast crank break? I've only read of one 700 iirc. Not sure if fluke or it really breaks at higher levels.
2. Is there any hardware difference between the CBT and CBU or is it just software?
3. Are the stock bore pistons, drop in for low mileage engines (less than 10k miles)?
4. Arp bolts - do the mains and head need Arps or will the stock ones be fine?
5. Who sells Mahle pistons?
6. Are valves and valvesprings necessary for 8krpm and whatever boost 550 needs?
7. How much power can a stock block hold?
8. Flywheel / starter- iroz or 1.8t 240m? - more concerned with starter config
9. Ecu - any preference?
10. Cluster - how to make tach work?
11. Are there any cheap cast manifolds that fit a longitudinal. Yup not ideal, but 1.8t have been making good power on cast log manifolds.
12. Intake manifold. Who sells flanges or longitudinal manfolds?
13 ac and ps. Which early models had them? I'm leaning towards te cbt/cbu just because they have both ac/ps and are available with very low mileage. But forged crank could change things a bit.
14. Rod crank bearings - is there any specific one that works better or will stock do?
15. Any problems arise after cutting the top bolts of an 01e?
16. How long does Iroz usually take to make and ship parts?
Iroz has off the shelf headers that are top notch proven
