FS: 4 cylinder to quattro clutch/flywheel kit
Posted: Mon May 09, 2016 10:03 am
the flywheel is a solid steel unit from a 2.0 audi 80, clutch is a 228 mm spec stage 2+, rated at 290 ft/lbs. This is a nice setup to put a 4 cylinder into a quattro car. Also could be used as a DMF elimination kit for a 1.8t b5 car. Flywheel weighs about 16-18lbs.
Clutch has 25 miles on it, in perfect shape. Excellent engagement. I want a heavier flywheel for my diesel with the 01e. This setup would work well with a TDI and an 01a, but not recommended for an 01e with a diesel. 01e and a gas engine would be no problem at all.
I have over $600 into this, but am a reasonable man. Make an offer, this clutch is essentially new.
