034 IIc - reverse polarity diode - help!
vbares
Post by vbares »
Hi - as most of you know, 034 MS has discontinued support of their ECUs...and of course, just in the knick of time, I've popped the reverse polarity diode:
crack in reverse polarity diode
2016-05-19 19.04.55.jpg (2.62 MiB) Viewed 7705 times
This is probably a $5 part - easy fix - if only I knew what part to order!! Does anyone know what the part number is, or the specs I should be looking for on it??
Thanks,
Vittorio -
