Audi 4000/CGT front outer CV Joints
90quattrocoupe
Post by 90quattrocoupe »
2 OEM Lobro front outer CV joints for:
84-87 4KQ
85-87 CGT except for the NG 5 cylinder cars running 108mm inner CVs.
85-87 4K FWD 4 cylinder and 5 cylinder cars.
If you want to look them up superceded part # is 321-498-099C.
They are in excellent shape with, no thread damage, no spline damage, no galling of the CV cage or the balls. They will need a through cleaning, as I only cleaned them enough to check the threads and the balls for galling.
They come with the plastic spacer and the concave metal ring. They do not come with the wire circlip. They have been sprayed with WD-40 to keep off the rust, after cleaning, and packed in plastic bags.
$45 for the pair. Shipping will be $13.45 USPS medium flat rate box.
Greg W.
