WTB: Holset HX35 turbo
morris400
Post by morris400 »
Looking for a Holset HX35 turbo with 12cm housing. Starting to collect parts for a Holset build and kinda need a turbo lol.
Thanks guys.
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
Re: WTB: Holset HX35 turbo
Post by Afterthought »
morris400 wrote:Looking for a Holset HX35 turbo with 12cm housing. Starting to collect parts for a Holset build and kinda need a turbo lol.
Thanks guys.
I have an H1C if you have any interest in that. It's internal WG but has the blocker plate over it.
Just call Goldfarb & Associates, a good HX35 core will run you $100-$150
Both good options ^^^
I'll sell you mine. Fully rebuilt 50 mm hx35 missing hotside. goldfarb could sell you the correct hotside you want for pretty cheap. I put probably 500 miles on it after rebuild. $150 shipped?
Not one problem with it. Rebuilt with turbolabs awesome kit from Amazon.com
BTW goldfab can sell you the 9 cm non-gated housing. That's what I ended up using.
morris400
Post by morris400 »
Wound up getting one from goldfarb. Hx35 with 56mm comp wheel and 12cm Non WG housing.
Thanks for the offer.
Good to hear you found the biggest one made. G&A, although a bargain, would only guess what size both holset I bought were. Never measured them and instead of getting that one the first the, they sold me the smallest hx35 ever made. I was...Happier after complaining.
morris400
Post by morris400 »
The guy I talked to said he measured it at 56mm. He said it's a hx40 wheel (which should be a 6 blade) but I'll measure it when it's here and see for myself.
He also told me it was just rebuild as well. All in $250 is not bad.
sounds like you got a pretty good deal. This the 56 mm I got the 2nd try. It made a full recovery lol, but not without hard work.
morris400
Post by morris400 »
That one looks beat the hell up. Mine came in today and it's damn near new. Hx40 8 blade comp wheel and housing, 12cm non WG ex housings.
Now I need to clean it up for sure, repaint the comp housing and sand blast the ex housing as well as tap the comp housing for WG.
Sounds like an awesome score then. I'll never lie and say I've had good luck with the 91. I can count on 2 hands all the problems so far thatve been out of my hands lol.
Let me be the first to ask for *pics* :)
