Bunch of stuff up for grabs.
Significant things are
VEMS PNP AAN ECU $1000 - Also check other for sale post specifically for this ECU SOLD
034 3071/k26 turbo. Fits on stock manifold flange. Will include lines too. $1000 SOLD
OEM RS2 Exhaust manifold $300 SOLD
034 3" down pipe $400 has a 2 bolt flange like stromung I believe? fits the exhaust perfectly. Tentatively SOLD
Samco hoses. whole set. $175 SOLD
OEM Wastegate. Top modified to be adjustable. has 1.8bar spring in it. $50
034 AAN 2.0T coil conversion harness. Will include Coils. $350
EFI Express LS2 coils, Coil Bracket, Spark plug wires, and pigtails for coils. No harness. You'll need to wire it. $250
Treadstone TR11 560HP intercooler $225 - Requires bumper mods. Recommend removing A/C Condenser to fit properly.
RS2 cams $300 SOLD
034 cold air intake $200 SOLD
034 poly snub mount and bracket $50 Tentatively SOLD
Lowering springs on Bilstein sports $200 for springs $400 for shocks $500 for both
Factory rear sway bar $300
Rear OEM brakes $150
AAN Coolant manifold. $60
AAN Intake Manifold $50
AAN Fuel Rail $20
Billet Diverter valve. 2 of them. $40 a piece
AAN Valve Cover includes apikol coil cover $75
7a Valve Cover $75
All interior up for grabs
Steering wheel. $75
Headlights, $50. Previous previous owner converted to HID's and the balasts failed. Probably easy to swap in new balasts and bulbs. Dunno. Your problem.
Taillights, cracked around keyhole. $50 for the set?
Factory narrow 1st 5 Speed 01e $150
Custom 3" Exhaust, with 1 cat and 1 rear muffler. Just the right amount of noise for the street. Not crazy loud. $500? Will not ship. Has a 2 bolt flange like a stebro. Fits the downpipe perfectly. Tentatively SOLD
B5 S4 HP2 Brake calipers and discs, barely used discs. Also barely used pads $200
Front bumper but a bit cup up - will not ship. throw me offers.
B8 A4 wheels. $500 with tires
Everything on the car is up for sale minus the front brakes, rear diff, and block.
Holla if you need anything. Open to offers on things if they don't seem priced right.
URs4 Part Out and many other things.
- IMG_20181101_215405.jpg (745.85 KiB) Viewed 17463 times
- IMG_20181101_215401.jpg (896 KiB) Viewed 17463 times
- 45211737_10156594053322211_779474175529058304_o.jpg (431.22 KiB) Viewed 17463 times
Re: URs4 Part Out and many other things.
Link to further Photos
https://photos.app.goo.gl/g4DDmbBMgf6A6svp8
Bumparoo
- IslandRinger
Are those 034 diverter valves? Interested in one of em.
Sent from my SM-G930W8 using Tapatalk
Tarpan (Victoria, BC)
Stable:
1986 Audi Coupe GT [SOLD]
Stable:
james12lucy
Do you still have the modified wastegate?
I do!james12lucy wrote:Do you still have the modified wastegate?
I still have them. They're the Ebay version but from my knowledge, they're literally the exact same as what 034 sold or sells.IslandRinger wrote:Are those 034 diverter valves? Interested in one of em.
