For Sale – remainder of parts from 2001 Audi A4 w/ AWM 1.8T. Car had 289K miles on it when parted. NOTE: buyer responsible for shipping, or I can meet to support local pickup. All prices are OR BEST REASONABLE OFFER.
1) Clutch/flywheel/pressure plate – not sure on mileage, but has no hot spots and still shows a lot of material on clutch disk, and was obviously replace at one point. - $50 for everything
2) Oil Pan (with oil level sensor) - $30
3) HVAC Fan - $5
4) ABS Pump – While hooked up, this showed no ABS errors. That being said, when I tried to hook up to it via VAGCOM, it wasn’t seeing it. Admittedly, I had a fair bit of the dash torn apart when I tried accessing it via VAGCOM, so that might have been the issue. - $20
5) DBW Gas Pedal - $20
6) Sport Springs – one rear (not broken) and two front - $40
7) Intake Manifold WITH Throttle Body - $40
8) Sunroof motor - $10
9) Jack Kit (complete) - $20
10) OEM Audi First Aid Kit - $20
11) Sport Steering Wheel w/ Airbag – no popped stitching, leather in great shape - $60
12) Brake Master Cylinder - $10
13) Brake Master Cylinder Reservoir - $10
14) 1.8T Mechanical Fan Assembly - $20
15) Homelink Visor - $40
16) Tail lights - $40 each
17) Dipstick Funnel w/ dipstick– (funnel itself is intact, but I cracked the mounting piece when removing. Still functional) - $10
18) Starter Motor – verified good - $40
19) AC Compressor - $20
20) Dash Cluster (center display pixelated) - $20
21) Shift Boot and shift knob - $50
22) Ashtray - $20
23) Hazard relay and fog light switches - $20
24) Double DIN setup (including center console surround) - $50
25) Center console (with arm rest) - $40
26) Wiper Motor assembly - $20
27) Fuel Pump Assembly (confirmed good) - $40
28) High pressure P/S Line (non-leaking)- $20
29) PS Pump - $30
30) PS Reservoir - $20
31) Carpet mats (driver’s mat has small hole at heel area, remainder of mats in fantastic shape) - $40
32) Air box w/ MAF and K&N filter (includes top cover as well) - $40
33) Calipers - $20 Each or $60 for whole set. Calipers all functioned perfectly, including e-brake
34) Exhaust manifold and turbo - $50
Turbo is in good shape and spins freely w/o any shaft play. One bolt broke off inside when disassembling, but can try to remove it prior if you want me to.
35) OEM Exhaust - $20
36) Cylinder head plus valve cover - $80
NOTE: Motor was overheated, which resulted in a blown HG. All valves are intact and not bent, but head will need to be looked over for straightness, etc.
37) Black interior - $100
Front seats are heated, but driver's base is cracked. Pass side and rear seats are in fantastic shape.
Parts are located in Arlington, VA.
Will accept cash or paypal. If doing paypal, request you cover fees. Buyer responsible for shipping if not picking up locally.
Feel free to email me <b>jretal at gmail</b> with any questions, etc.
