stock parts:
- rain tray (protects heater & fuse box)
- Heater box (in good condition, preferably rebuilt or fan & flaps to rebuild mine)
- fuse box
- black rear seat
- drivers door card pocket
- passenger seat belt retractor
- black floor mats
- instrument cluster or parts to fix mine (odometer)
- weather seals (all around but drivers door sill is a must)
Upgraded parts:
- B3 rear subframe
- Ur quattro firewall brace
- wheel studs
- racing radiator (dual or quad core)
- short shift kit (all metal preferably)
- 3b clutch (for future 7a swap)
- Ronal R38's (17" x 7.5, 4x108)
wtb: 4k wish list
Re: wtb: 4k wish list
IIRC you can still get the rain tray new from audi and that would be the way to go as most are brittle and usually cracked/destroyed. Wheel studs you will want to find new also. I got my studs and nuts from prestige wheel, but all the usual suspects carry them.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
Is the rain tray the same as the URQ?
nsimps wrote:Is the rain tray the same as the URQ?
Yes, in fact the one on my car is from a URQ.
Dan
1984 Ur quattro
1984 Ur quattro
where can i get a part number for either 4k or urq?
811-819-099-A for the rain tray, also known by Audi as the "Deflector"
Hey this is my first post! Good luck finding the rest of your parts.
Here is something I posted somewhere else about the odometer gear....
http://www.odometergears.com/cable.html
The gears seem expensive at close to $30, but they are really easy to change and are supposed to be of much better quality than the originals.
I didn't take a picture of the one that I fixed but here is a picture of the next one I'm going to do.
http://photos.foxgti.com/i.ashx?&mid=15 ... e=1024x768
Count the teeth on the old gear before ordering a new one.
It's probably a good idea to have someone hold pressure on the back of the odometer shaft while you press the new gear on.
Wow GREAT!!! Thanks so much, what a generous first post!
