Selling a used KKK brand turbine housing. Its a higher flowing #8 sized housing (originally found on Porsche 944S turbo models)
Its been enamel coated (not installed or used since then)
This housing is machined to be used on a Garrett journal bearing center section only. It was previously fitted to a Garrett center section with a Stage 2 turbine wheel. Can be bored to fit larger wheels as well.
Great for a T04/K26 setup.
