Interested in getting a 3B head. Anyone know differences in 3B/AAN?
Looking for spare/one to be fully built.
Thanks,
Nick
WTB: 3B Engine Head
WTB: 3B Engine Head
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
Re: WTB: 3B Engine block/Head
they are different. aan accessory bracketry won't bolt up to 3b. dont know if it will the other way around either. better off using correct block.
Re: WTB: 3B Engine Head
More on topic... The heads are basically the same. AAN had a bracket for the cam sensor and the 3B was set up for a distributor. I have an AAN head with a plug in the distributor hole that I picked up to build, so it should serve my purposes. Just make sure whatever head you get has a hole for the distributor.
Sent from my SM-T210R using Tapatalk
- amd is the best
7A heads can be used with the proper water manifold machining too. Usually in better shape than the turbo heads too. Always an option if you find one cheap.
amd is the best wrote:7A heads can be used with the proper water manifold machining too. Usually in better shape than the turbo heads too. Always an option if you find one cheap.
Thanks! I will look into that. Finding an affordable 3B head is pretty hard and I want to keep mine running during all the machine work.
I've got a 7a head complete with cams. Was running a week ago.
