Most of you know, but maybe some don't so I'd like to get the word out.
A good friend of mine owns http://www.FuelInjectorDevelopment.com and supplies Bosch Motorsport EV14 injectors.
I want to give you guys the opportunity to purchase EV14 injectors at a reasonable price, so I have become a dealer for the FID products. Here is a list of the offerings. Prices are for a set of four. For five, divide the price by four and multiply by five. The prices here are retail. I can do significantly better for you guys, just PM me.
Also, there are various vendors on this website who can supply you with this brand of injectors. EFIexpress is one, and I believe Iroz Motorsport is a dealer as well. Feel free to get them wherever you choose. As long as you guys are getting a great deal, I'm happy
And no, noone told me to add this paragraph, I just felt that it was the right thing to do! ************************************************************************************************************************************
630cc Ev14 High Impedance Fuel Injector. Matched within 1% static flow and 2% dynamically giving great cylinder to cylinder consistency and amazing idle quality. Compatible with all fuels including gasoline, ethanol, and methanol. Ev6 Connector. $250
750cc Ev14 High Impedance Fuel Injector. Linear to ~1.25ms. Matched within 1% static flow and 2% dynamically giving great cylinder to cylinder consistency and amazing idle quality. Compatible with all fuels including gasoline, ethanol, and methanol. Sumitomo/Denso Connector. $285
850cc Ev14 High Impedance Fuel Injector. Matched within 1% static flow and 2% dynamically giving great cylinder to cylinder consistency and amazing idle quality. Compatible with all fuels including gasoline, ethanol, and methanol. Ev6 Connector. $320
1000cc Ev14 High Impedance Fuel Injector. Matched within 1% static flow and 2% dynamically giving great cylinder to cylinder consistency and amazing idle quality. Compatible with all fuels including gasoline, ethanol, and methanol. Ev6 Connector. $360
1200cc Ev14 High Impedance Fuel Injector. Matched within 1% static flow and 2% dynamically giving great cylinder to cylinder consistency and amazing idle quality. Compatible with all fuels including gasoline, ethanol, and methanol. Ev1 Connector. $450
1400cc I don't have the official description of these handy, but they are an EV14 high impedance fuel injector made for a high end OEM. These will be going on my 200 sedan build. $625
1600/1700cc injector is in the works! More details to come. Please state your interest in this thread if you would like a set.
2000cc Ev14 High Impedance Fuel Injector. Matched within 1% static flow and 2.5% dynamically giving great cylinder to cylinder consistency and amazing idle quality. DO NOT USE WITH VP Import, Q16 or OTHER MTBE OXYGENATED FUELS. Sumitomo/Denso Connector. $645
Let me know here or via PM that you are interested.
*NOTICE!*
When running ANY fuel injector, make sure to change your fuel filter out to avoid any problems with seizing or sticking. It states right on the flow sheet that comes with these injectors that the warranty is only valid when the injectors are installed with a properly maintained fuel filtration system. Be sure to change your fuel filter! If you're running E-85, make sure your filtration setup is compatible.
Another note is that when running E-85, deposits can form on the injectors in the form of a sticky, black, goo. For more information on this substance, it's origins, and how to keep it under control, refer to this post. http://forums.nasioc.com/forums/showpost.php?p=37242444&postcount=42
