Both door lock assemblies (heated), ignition lock assembly, trunk/hatch lock assembly, central locking pump w/pigtails and the original switchblade key fob from a 1998 Cabriolet. The door locks are pretty much plug and play - the outside of the door lock (the part you see inside the door handle) is slightly larger than the old style so you need the door handle trim plates from a pre-facelift A4/A8 or later C4 A6/S6; the central locking pump will require some wiring to get keyless entry working.
$350 for the set shipped.
I also have the door handles and trim plates from the Cabriolet available (laser red) for an additional $50 if you need/want those as well.
