Plans...use same turbo ive had, 6765 (which needs a seal job which means itll be a 6766 on its return) to make hopefully a metric fuckwad of power.
Head will get valve springs, and possibly cams if they are available once this project is done. custom manifolds of course.
Motor will get rods, most likely IE Tuscans, JE pistons and apparently a $1,000 TTRS crankshaft. i was told that cast cranks in the 4 cylinder 20v's didnt handle too much power. but mine seemed to be fine with 600+ for a while there. but i would rather not risk it this time around.
what the motor looks like. from a 2012 jetta, 18k on it. traded my VR for it.
and a sneak peak of the layout of some parts ill get cut on a waterjet for the cooling system, because i need to -AN all the things.
I know..crazy
