1984 Ur-quattro 20vt, 336whp 380 torques, 6-speed
Audiurq
Re: 1984 Ur-q with 20vt and 6-speed aka Shannon, she drove!!
Post by Audiurq »
:pics: or it hasn't moved :D
Seriously though - well done Martin, it has come a long way since we first saw the three of them!
Be nice to have all that space back in the garage. BTW, if it is any consollation it is raining quite a bit here too....
ralleyquattro
Post by ralleyquattro »
ShavedQuattro wrote:So you have all forward and reverse gears martin? That is exciting. The spacer fit pretty well? I didn't have time to throw that one in the CNC, so it was done with the good ol fashion punch and drill press for the 6 holes. I hope it wasn't too much of a pain to get in there.
Hi Hank,
Arrived Monday morning, thank you!!
No problems at all, fits where it touches.
Cheers
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
ralleyquattro
audiurq wrote::pics: or it hasn't moved :D
Thanks Mike,
The driveway is full so not sure where to put this one to make space in the garage, might have to ask Mark if I can store Brianna back up there... I'll be hoping to put few miles on this one this summer. Brianna can have a break.
Cheers
Martin Pajak
91 Coupe Quattro
Quattro Krant
Post by Quattro Krant »
Martin-I really want to make it up north for the next gathering and see this in person.
Highlander
Post by Highlander »
IS IT DONE YET???????????????
Quattro Krant
Hank-Martin has been trying to find a way to come up with money to buy my 85. All work has since stopped on his 84.
ralleyquattro
Hi Richard, wanna trade?? ;)
Update is.. since Carlise I haven't done squat... tonight though... boguht the alt and p/s belts and going to put them on.
Only other thing is some small vacuum leak that keeps stalling the engine at idle.
I hope to have Craig pick it up Friday and take it to his shop for aligment and safety inspection, Craig, let me know if that will work for you.
Other than that she's ready apart from some small stuff, like.
Installing front sway bar, oil cooler and bottom rad shrouds.
Cheers
Martin Pajak
91 Coupe Quattro
Highlander
Hurry the hell up.
I don't have or need a front sway bar
Cheers
ralleyquattro
So Friday morning it is? Remember to bring your dealer plate ;)
BTW I still have to push the rear bumper in.
Martin Pajak
91 Coupe Quattro
ralleyquattro
Here are some pics the appraiser took last week:
Martin Pajak
91 Coupe Quattro
Quattro Krant
ralleyquattro wrote:Hi Richard, wanna trade?? ;)
Only for money :wink:
AudiSport4000
Post by AudiSport4000 »
Wow, looks gorgeous Martin!! :)
1986 4kq Commemorative Design
2012 Jetta TDI
Tonks4x4
Post by Tonks4x4 »
Nice looking machine Martin!!!! :)
Audiurq
Post by Audiurq »
aboot time! feck :D
ralleyquattro
Thanks guys, just talked to Craig and safety and alignment will happen on Monday. It will give me the weekend to figure out this idle problem as well.
The evening wasn't a total loss, one of the belts did fit, the other not, and got the tachometer to work as well, spliced the wrong wire.
Also, what do you think about this one? Toying with the idea of using my old Scheel Mann
Martin Pajak
91 Coupe Quattro
nm_audi
Post by nm_audi »
Beautiful!!!
My vote - do it!
I like the body colored wing I have decided. The car looks amazing.
RufCTR
Post by RufCTR »
Car looks great Martin... best of luck with it. :)
Highlander
Looking good Martin.
I look forward to driving it on Monday
:drive:
I'm curious how that wee turbo will make out, and I'm looking forward
to verifying that the boost is working correctly
8)
ralleyquattro
Just remember to bring your CAA card with you :o
Martin Pajak
91 Coupe Quattro
ralleyquattro
So.. Craig set off this morning to take her to his ship for Alignment and Safety.
I'll let him fill in the details. :frustrated:
Martin Pajak
91 Coupe Quattro
1wheelpeel
Post by 1wheelpeel »
ralleyquattro wrote:So.. Craig set off this morning to take her to his ship for Alignment and Safety.
The suspense is killing me.... Martin, I hope this wasn't another brake proportioning valve issue. lol Seriously though, I hope everything went ok. I really, really want to see this car on Thursday.
ralleyquattro
Something in that style... more of a problem is inability for it to idle.
I am going to throw in set of stock injectors and try a stock ECU to rule those out, otherwise everything checks out. Hope to make it for the Thursday night, have the plate and sticker all ready, Just need it to behave.
Martin Pajak
91 Coupe Quattro
regarding the idle, is this on VEMS? email me a datalog if so, there are probably some settings to update. also, do you have the 2-pin idle diode adapter?
ralleyquattro
Hi Mark,
Thanks for the offer, but this is on Motronic.
I want to get it going on Motronic and make sure everything works properly before I jump into VEMS.
Yes, I have the diode adapter.
The car is running very rich and hard to keep it idling, especially when it warms up.
We are having issues communicating with the ECU, might be because of the chipset.
I've put stock injectors back in and hope to get a stock ECU tonight to eliminate bad ECU/chip issues.
Once I know it runs well/crap on stock computer/injectors I can go from there.
We can't find any vacuum leaks and the only code I get is for the crank position, but that code is normal when you pull codes with engine off.
Cheers
Martin Pajak
91 Coupe Quattro
