Audi 90 quattro with 2.5 TDI and 6-speed, plan B
barfbasket
Re: B4 90 quattro with 2.5 TDI now running!!
Post by barfbasket »
Divide Litres by Kilometers and multiply by 100
ralleyquattro
Post by ralleyquattro »
Fuel used /(Km driven/100). That's all.
If I used 50L and drove 1000km that would make it 50/(1000/100) i.e. 50/10 which is 5L/100km.
Cheers
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
T-Rex
Post by T-Rex »
Did you get your bumper? Cant wait to see it on a car.
ralleyquattro
Yep, picked it up this morning.
It was worth the 2 hour drive each way!
Andrew Warner was nice enough to the work on the Rieger RS2 bumper for me. :thanks:
He installed some mesh holders which the bumper does not come with.
He also fixed up one corner that had a chunk missing
Shot some pearl white to match the car
And I liked Technoquattro's bumper so much I also asked Andrew to the same to mine.
I am very impressed with Andrew's work. Bumper looks stunning. Makes the rest of the car look like a POS. :lol:
Next I have to make up some brackets to mount this beast on the car, and then install some 993 fogs and turn signals.
Cheers
Martin Pajak
91 Coupe Quattro
ralleyquattro
Delete
Martin Pajak
91 Coupe Quattro
T-Rex
Post by T-Rex »
Nice! That's gonna be one aggressive looking diesel.
The bumper doesn't come with any mounting brackets? That sucks. The sides are easy to bolt onto the fenders, but on the front you gotta be creative.
ralleyquattro
I plan on copying what this guy did on S2 forum.
http://www.s2forum.com/forum/showthread.php?t=23388" onclick="window.open(this.href);return false;
Martin Pajak
91 Coupe Quattro
Post by ChrisAudi80 »
nismo wrote:Question for you Martin. To get our mileage, we just divide miles by gallons used, and its pretty easy. In using the metric system, I'm assuming its a bit more complicated...or do you have a shortcut that gets you there?
Eric
Metric works the same. Kilometers divided by liters. However, in Europe many times fuel consumption is expressed as liters per 100km.
To give an example, my S6 uses 16 to 18 liters per 100kms. That is what the display on the BC says.
I also record each fuel stop. Then, I just divide the kms with the ltrs. Usually 330km and 65 liters.
Expensive car to run. The diesel getting 5 or 6ltrs/100kms is damn good.
smirre
Post by smirre »
Eric
I know I'm not Martin, but anyway this is usefull
http://tdiclub.com/misc/conversions.html" onclick="window.open(this.href);return false;
ralleyquattro
Nice conversion page, thank you!
Martin Pajak
91 Coupe Quattro
1wheelpeel
Post by 1wheelpeel »
Andrew has some mad skills. That's one gorgeous paint job! I wonder what his schedule is like this spring? :wink:
ralleyquattro
Not much else happened, gathering stuff and waiting for few things from few places.
Started working on brackets for the bumper.
Here is what it will look like with used 993 fog and new turn signal.
Mockup on the car
And with hood a bit closed.
Need to find some RS2 lights to match the look.
Got the brackets mocked up and will be doing some real bending tonight at Craigs.. ;)
Cheers
Martin Pajak
91 Coupe Quattro
Andrew is the man - that is one sexy bumper!
Highlander
Post by Highlander »
Yes nice work for sure.
Now get it done ..............................
WOMBAT
Post by WOMBAT »
best diesel ever!
death 4kqt
Post by death 4kqt »
i dont know casey, my diesel converted wheel horse is pretty bitchin
:P
this is a 90 that should have been offered world wide!! diesel dd FTW.
Wheeljack
Post by Wheeljack »
Nice, Martin. This is one of the coolest TDI's out there.
I like the technoquatt approach to the two-tone scheme. It really helps with the lines of the car while retaining the black lowers on the back half. There isn't much else you can do with the way the RS2 bumper is designed.
http://brydon-eng.com
ralleyquattro
Thanks guys!
Yep, I liked his bumper and decided it would best match the rest of the trim.
More tomorrow.
Martin Pajak
91 Coupe Quattro
Lord_Verminaard
Post by Lord_Verminaard »
ralleyquattro wrote:More tomorrow.
Well, it's tomorrow!! :lol:
Brendan
2005 New Beetle TDI
2002 Jetta Wagon 1.8t Tiptronic to manual swap (Wife's car and kid hauler)
1981 Scirocco S'...
1976 KZ400
ralleyquattro
Yes, indeed.
GOt one of the packages I was waiting for... but more dissapointment.
I was hoping to run the B3 coolant and P/S reservoirs to make them fit better around the rad... not so.
The B3 coolant jug will not fit bcause of the ABS crap in the way.
So... back to stock, B4 coolant and B4 P/S jug are in, not my favorite, but at least it all fits.
GOt the heater core lines in as well... but discovered another issue.
The stock typ 89 rad shroud will not fit the body, the B3 has a nice little cutout that the B4 does not, so the rad shroud hits.
I wonder if the RS2 one will clear, will have to talk to technoquattro to see what he did (or read his writeup a bit better).
Frustrated I decided to see how my brackets turned out. I bent them at Craig's shop last night, sort of sucks because I was working from a piece of tin I bent up and had no way of testing the actual pieces... but they turned out great.
And got the body to bumper bracket mounted on the drives side, then it started to rain and I had to stop, but it looks great.
Hope to finish the other side this evening.
Martin Pajak
91 Coupe Quattro
T-Rex
Post by T-Rex »
It does look great! Makes me want to get that bumper. Well, some day.
80qtdi
Post by 80qtdi »
WOMBAT wrote:best diesel ever!
Definitely one of the faster builds, but I wouldn't say the best :D.
Kidding aside, great work Martin...
ralleyquattro
Got the other side mounted and bracket finished. Now, If I have them powdercoated I might not see them for 2 weeks, if I just throw some paint on them I can get them mounted and on the car this afternoon... decisions decisions.
Today plan is to get the cluster rewired and keep going on the engine compartment.
- vacuum pump mounting, routing and swith/relay wired
- figure out the fan housing sitiation
- Still need a P/S belt, the stock one is too short.
Pushing on.
Martin Pajak
91 Coupe Quattro
Pffft, obviously my //S conversion will be the best. :lol:
And yeah, kidding aside great work :)
ralleyquattro
Very productive day today.
Filled up gearbox with oil, bled the clutch, flushed the brakes with new fluid.
Finished welding the exhuast (mid pipe).
Installed AIT in the intercooler outlet.
Got the cooling system ready for fill up (don't have any coolant here though).
Finished mounting the bumper after painting the brackets.
I am really happy with the gaps.
And got the car back on the gound.
Tomorrow is gauge cluster, and troubleshooting of the glow plug relay circuit.
Hope to be test driving on Sunday!
Anyone know if the clear corners from a B3 will fit the B4? I know the headlights are different due to the hood grill.
Cheers
Martin Pajak
91 Coupe Quattro
