Thanks man!dubsmith wrote:Wow dude! You can doo eet! That k26 looks tiny
@ Hairball II : Thanks man! I can't wait either!
@ Darin... :slap:
Yup, sure am! I am going to order that last because it will be pretty much plug and play by the time it gets here. At least that's the plan.pilihp2 wrote:I can't remember. You're doing vems off the start, right?
Awesome, thank you sir!mr_aj_johnson wrote:No need for a narrow band then.
Like a glove!Audilard wrote:How does it fit?
:slap:Audilard wrote:Is it done yet?
I chose to go with an AWIC because it's a good compromise between efficiency and space. Also I didn't want to hack up the front end just to fit an AAIC. :-)JonathanL wrote:Looks sweet, not bashing at all but why awic?
I can guarantee it's going to rub like crazy over bumps.loxxrider wrote:No way man ride height looks goodAlso, where are you going to run the pipe from turbo to IC?
I will more than likely change to 40s after I drive it for awhile.40v4kq wrote:LOL I understand cheap tires. 40 would be ideal for look but i bet you will find the 45 series to be more confortable for daily duty. I noticed a huge difference when i took off the original BBS 15" wheels and put the 17" ASA AR1's on my GLI with 205 40 tires. The car is quite a lot stiffer and doesnt glide over bumps anymore. FWIW, the tires on my 4kq are 45 series so they have a fairly fat sidewall which i'm ok with :-)
Thanks Darin!Audilard wrote:Nice Ben! Keep it up, we are rooting for you!
It does feel great!40v4kq wrote:Its nice to watch your to-do list shrink, isnt it :-) Dont forget to put oil in the motor, if you havnt done that yet just go get it over with so you dont forget with all the excitement.
