I watched this car on a local forum for about a year (plagued with low oil pressure, peeling clear coat), then pounced when the price was right & I could logistically swing the deal.
Initially I'd intended to use the car for parts in a suspension/subframe overhaul on my Black Cq, but I've since changed direction.
Now that all of my parts are in from 034, and both cars are shoehorned into the garage, I have begun my "other" project... :slap:
Plan is to swap the motor from my Black car into the Red 'parts car' and drive Red during winters and to/from work. That way, Black can be a pretty turbo car for summer and special events.
There are a few things that may or do need to be repaired on Red before I can call her roadworthy/go for insurance mechanical inspection:
- tires
- motor swap
- passenger headlight
- emergency brake
- passenger window motor
I'll have to look into the hydro-bomb some more. It may warrant a vac swap sooner than later.
Since Black will be off the road a while with a drivetrain refurb, I will purloin some parts from Black to use on Red that won't be missed any time soon and do some jobs that are easier now; aka, While I'm In There...
- K&N air filter (edit)
- Euro V6 front bumper/S2 fogs
- OEM leather shift knob
- S2 3-spoke steering wheel
- ARP head studs
- 034 motor/trans mounts (street density)
- 034 7A EFI upgrade & relay
- 034 phenolic intake manifold spacer
- ceramic coated bag'o'snakes header & downpipe
- coolant/brake/tans/motor oil flush
The inbound 7A from Black has ~300k km on the clock. Red's chassis has 205xxx km. I'll perform the next TB service at 250k km as per Red's odometer reading.
that should take care of the oil light.
