FS: $4,500 Casey's 200 20v
death 4kqt
Re: Casey's 200 20v: IT RUNS!!!WOOOO!!!!
sounds mean, its going to sound evil with boostage.
groff
seeeeeee, glad you finally adopted my mentality now!WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
death 4kqt
Thats how i do it, ive started engines with no exhaust manifolds etc.... i started up a virago 1000 motor that i just rebuilt the other day on the floor..couldnt wait to get it in the bike...groff wrote:seeeeeee, glad you finally adopted my mentality now!WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
groff
death 4kqt wrote:[/quote]
damn near did a compression test on the engine stand in my dining room last month by cranking it over off the truck battery, but decided against that after seeing the junk accumlated in the cylinder head
Thats how i do it, ive started engines with no exhaust manifolds etc.... i started up a virago 1000 motor that i just rebuilt the other day on the floor..couldnt wait to get it in the bike...[/quote]groff wrote:seeeeeee, glad you finally adopted my mentality now!WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
My turbo oil feel leaks between the center section and the brass NPT adapter.
Teflon tape or crush washers?
death 4kqt wrote:[/quote]sounds mean, its going to sound evil with boostage.[/quote]
Hell yes it will!
Did you use the stainless steel universal coolant hoses on your car? If so, are they worth it?
Hell yes it will!
groff
tape until a new JEGSSSSSSSSSSSSSS fitting arrives that isn't brassWOMBAT wrote:My turbo oil feel leaks between the center section and the brass NPT adapter.
tape and crank it tighter
death 4kqt
sounds mean, its going to sound evil with boostage.[/quote]WOMBAT wrote:death 4kqt wrote:
Hell yes it will!
Did you use the stainless steel universal coolant hoses on your car? If so, are they worth it?[/quote]
I used it, and it works, but i don't really like it. I don't really have any choice without some major reworking, so that is why I used it. It has served its purpose, so i guess I am satisfied with it.
Yea I might have to use them. The car has 1.25" I/O and the radiator has 1.5" and 1.75" I/O
lots of oem rad hoses have small flare/transitions on the ends
or another option
im making 1.25" mandrel alu water pipes for my 16vt 4kq, and using 1.25>1.0" reducer elbows off the block connections and 1.25" straight silicone hump hoses to connect to the b3 80 radiator
or another option
death 4kqt
can you have the outlets of the radiator reworked with sizes and locations that would allow stock type hoses? I always find myself wishing my car could run all stock hoses.
I lucked out. Went to Advance Auto with some bent up coat hangers and a tape measure and ended up with some decent radiator hoses!
Before: only used the two larger hoses
After:
Installed:
Good to go!
After:
Installed:
Good to go!
get some non perforated clamps on those!
Oh hush, you
groff
needs moar bling to be a show car!
Rallyfreak202
Hell yeah Casey! Nice stuff man.
I drove it a blistering 15mph this morning around my block! Never been so excited to drive so slow haha - it felt great! Also realized I hadn't filled my hydraulic system yet, oops.
Filled the hydro system and that's all well and good. It sounded like I had air in the ps pump but it turns out it was my distributor rattling... That can't be good for timing accuracy. Can dizzys be rebuilt?
yes, can be rebuilt
Is that a DIY item or send out for rebuild kind of thing
yodasfro
Depends on what version of the distributor you have and what parts you intend on replacing? Do you have a metal gear or stock plastic?
Metal gear - not sure if it's a matter of shimming or if the bearings have play
yodasfro
Shims there are no bearings.
