derracuda
i'll check it out after a little while to see how things look and let ya know
if i was just going to leave it open to atmosphere, i could see it rusting rather easy (the amount of moisture taken into my old breather can setup was rediculous!), but this will be closed loop, and should be pretty much oily vapor.
derracuda
annnddd, a little more progress today.
i needed a support for the fuel line, and a little block with a tapped hole was the solution
the trimmed fenderwell needed something on the edge of the sheetmetal, and while at the wrecking yard i found some sweet small trim from the sunroof area of a 944.
the fuel lines needed construction as well. black ano. fittings and the black braided lines are teh zechsay
also had to make up the turbo oil return line
in order to consider the manifold "finished", i had to have the mounting surfaces checked, so the i took it over the machine shop, the checked it and said... "perfect!".. wow. good welding Nubz 8) after that i just needed to do a little touch up polishing with the steel wool and then clear coat it. i like how the clear makes it a little more satin finish 8)
mmm "big turbo kit"
mmm "big turbo kit"
HT Motorsport
derracuda
thing is, i don't feel like i'm moving fast enough :( i am going to miss my next trip to CA to go get my fiancee (K1 fiancee Visa approved btw
) and i won't be able to touch the car for about 5 weeks. so i'm trying to cram as much as possible, plus work on regular work, and then my buddy's 4kq v8 conversion tomorrow... and tonight i'm pulling the engine and trans from a passat. ARG~!
Enough with the progress already...sheesh I am trying to take a night off here and you are making em feel bad.
Is this where we discuss the fire calling the kettle black? Between the two of you I'm about ready to take up lawn bowling or maybe curling.
The car is looking fast and very well sorted. It's going to be nice!!
I thought it was the pot calling the kettle black?quattro87 wrote:Is this where we discuss the fire calling the kettle black? Between the two of you I'm about ready to take up lawn bowling or maybe curling...
But good point, those two set bad (good) examples for everyone.
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
'07 Toyota Tundra CrewMax (for towing/hauling)
I knew that it didn't sound right, but for the life of me couldn't come up with anything other than the general idea. :bashtard: I'm not sure which Haydn would rather be called anyway...a fire or a pot.RSCoupe wrote:I thought it was the pot calling the kettle black?quattro87 wrote:Is this where we discuss the fire calling the kettle black? Between the two of you I'm about ready to take up lawn bowling or maybe curling...![]()
derracuda
nothing today :( work kicked my butt today. 8:15am-11:30 tonight. blah. yesterday i was going until 12:15, got to bed at 1.. arg! too little sleep does weird things to the body and mind.. none of them pleasant
i should have a surfaced exhaust manifold tomorrow.... maybe i get time to pull the engine and gut it before i head out of town again.
Derric you make me SICK! Your car is going to be such a badass. Here I am planning on just buying all of my chiz prefabbed up (IE O34) and here you are making such killer custom toys. At least you give me plunty of motovation!!! I hope I get to see this beast in person somday (maybe at the show at woodburn).mmm "big turbo kit"
If you get excited an make more, I will be in the market to buy for sure!!! :-Dwelll, i have my car to put one on, and my buddies... we'll see how things go when i get there
derracuda
a_CQ
derracuda
quattrostyle
derracuda
wow derek great progress, i cant wait for this thing to fire back up!!!!1 :woowoo: :woowoo:
HT Motorsport
derracuda
... Dang Derek, I just went through you thread once again and I have to say your work me a crap ton of inspiration. So clean and I just watched you exhaust videos on youtube again... and damn. I want that sound SOOOOOO bad. I swear I make the least amount of progress out of anyone on this board. I need to kick it up a gear! :bashtard:
