Tim's '86 BLAZE 4kq EPIC PROGESS!!!!
Re: Tim's '86 ex-Zermatt 4kq, how longs a 7a swap take?
getn close
major progress, pics later
waiting on one small part here monday, and its DD status for this and back to work on the coupe
death 4kqt
Post by death 4kqt »
nah
yup
Hybrid_Hatch
Post by Hybrid_Hatch »
Depending on your post office that one part might be there saturday.
yea that part will be here, but not the carrier bearing
audidub
Post by audidub »
i have a carrier bearing, new in the package
wooohooo coming to get it tonight, less delays the better!!
thanks
carrier supply will be replentished soon
mini update, pics to come later
motor and trans is in
wiring is run
front passenger axle is being a bitch
i gots no fueling connection
ok so
the feed and return line are bent and ready to be connected, one of the lines screws right together, and the other side wont
the 7a fuel line off the fpr has a female fitting and the return off firewall is male, but not the right size, so there is that coupler nut piece that fits the male off firewall but i need a fitting/adapter of somesort to get it to connect, anyone?
ok so ive spent too much time swapping axles and cv's back and forth agh too long
with the urs4 5 speed in place
and the 4kq output cups shortened
the b3 90 20v front axle is still too long and wont even get close enouh for the balljoint @ max camber
the 4kq pass front is too short and binds under steering
i need an axle that will take a 4kq outer cv, and a 100mm inner or similar spline so i can use 100's
anyone want to buy a complete 7a swap?
death 4kqt
fail
4kq o1e fail
Sciroccohp
Post by Sciroccohp »
cant you make a spacer to make the 4K one long enough?
audidub
Post by audidub »
trade you a built intake :D
audidub wrote:trade you a built intake :D
for tha 7a swap?
can i run a 16v on mk3 mgt? its efi ya? but is it doable
Sciroccohp wrote:cant you make a spacer to make the 4K one long enough?
yeah i could
ive also had thoughts of b3 c-arms, knuckles etc, to widen it all out and it should work fine
im in need of a set of g60 calipers and rotors so i can run a full b3 front end
and make those damn axles work
or damnit and figure out how far to space the stock pass side axle so that it works
ralleyquattro
Post by ralleyquattro »
I have a set of CQ G60s.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
pads rotors ad whatnot?
price shipped to 03255
glibobbo21
Post by glibobbo21 »
as do i
im going to try making a ~15mm spacer tonight
ill see how it works and then decide what way to go,
jim, that tie rod i let you borrow, i got one from the wht parts car, but i believe its a drivers side as its waaaay too long, is the passenger kicking around there?
glibobbo21
dunno but i DID buy you an outer tie rod the other day
glibobbo21 wrote:dunno but i DID buy you an outer tie rod the other day
end? or complete?
well dang musta slipped my brain, ill get you some loot
audidub
Post by audidub »
i got a set of g60's in the scrap pile, they are kinda rusty but if you want them their yours
