future goals are obviously big power. i already have a spare engine and many of the head parts i plan on using. still need bottom end stuff but slowly accumulating parts as time goes by and i keep adding miles to the 280k+ mile engine.
the rear bumper was actually almost a direct bolt up minus the exhaust cutout being in a different location and having to build brackets on the sides to tuck the corners in.
the front bumper i did like i have seen others do used parts from both bumper shocks, cut and welded together to get both surfaces to mate as they should. on the sides i used a long skinny bolt through the holes used to mount the lights through the fender and nut on the inside of the engine bay. this also helped me to tuck the corners in on the front bumper as well.
the carpet kit was not new as i couldnt find one
i removed my carpet, pressure washed it, and died it black. just found a set of black s6 seats locally so those should be picked up this week!
