This thread used to be for my 635csi only, but I don't want to muck up the forum with a ton of other threads for other BMWs with marginal project status, so I decided that this will just be a collective thread for all of them.
The cars involved include:
1985 635csi 5MT
1989 turbo'd E30 (5MT) (not mine)
1990 M3
1994 530i (mini V8) 5MT
1998 328i with M3 suspension and other sporty goodies (5MT)
2001 330i (5MT)
2001 M5 (6MT)
2009 Porsche Cayenne Turbo S
Hope you enjoy it and get your BMW fix here
The original 635csi post starts below:
Well, I went and did it. After looking at one *euro* (see bottom of post) 635csi, an NA spec M6, and considering two other M635's, I bought the euro 635 csi. I got scared away from all of the other cars for various reasons. I even almost got scared away from this one because of some rust issues, but I'm glad I went through with it.
When I went to look at the car again today, I checked the inner fender wells, inside of the strut towers, etc. and found that everything was coated with undercoating. Thank goodness! All felt solid in there. The underside of the car is also very clean amazingly. After that, I was confident enough to hand over the cash and drive the car home. It did so beautifully, and I couldn't be happier for what the car is (a daily). It is very solid mechanically, and drives quite nicely minus huge body roll around corners. There are no clunks, it runs smoothly, etc. Clutch feels good, the power is all there, all of the windows work, sunroof works, almost everything works in the car. Most importantly, the rust isn't even close to as bad as I thought it was. I'm very happy about that! I suppose I could be happier if it had AC. That is on the to-do list.
So, the to-do list is as follows so far:
Immediate future
-put my polished style 5's on (gotta get tires first) Done
-new front fenders Bought, but not painted or installed
-re-spray sunroof, panel in front of the hood, etc. Sprayed nose, still need to do sunroof
-take the seat brackets out and clean them up/tighten up Done
-get the temperature gauge working (car has new rad and rad fan, water pump, etc., but I still don't like driving without a temp gauge)... either the gauge itself or the sender, we'll see Done, problem was in the cluster
-air conditioning (compressor will turn on, but will blow the fuse after 5-10 minutes
Sometime soon (maybe within the year)
-make the car not handle like a pig (coilovers using Bilstein sports [shorten front struts] and Eibach 2.5" coil springs, etc.) Done
Eventually if I keep it (this is what will make it a Project Pad project
-Standalone engine management (either VEMS or MS2/3)... if for nothing else, to make it more fuel efficient and run better than it does with the stupid trap-door air flow meter and WOT switch Bought and built, but still need to install
-turbo
Here are a few pictures. It started raining out as soon as I got home, so I'm sorry about the quality. I need to break out the DSLR for some good shots when the style 5's are mounted. Speaking of the rain, I couldn't help but "check" if the car has an LSD by getting a little sideways on the way home (thanks 218 hp euro M30!). I think it does. I'll have to take a look when it stops raining.
Most of the stable, but not all of it. The best one is in super-duper project mode!
Style 5's that will go on this car. Just waiting on some new nuts from Wokke.de.
Also, here is a picture from the craigslist ad so you can see what it looks like with the style 5's on it. He kept his set. I didn't need any more wheels in the garage.
*The euro E24's (6 series) came with significantly better looking bumpers, were a few hundred pounds lighter, and had about 30 more hp (215-ish vs. 185-ish) than their US-spec counterparts. That makes for a much more desirable car. Add the fact that all of the interior buttons are written in German, and I couldn't help but fall in love with the car. It's just cool!*
