Your dream built, bored out, high boost, stroker engine.
Unassembled. Add $900 for assembly and machining of block.
-236mm tall deck block
-NLA 92.8mm crank
-New Iroz 160mm rods
-New coated rod and main bearings
-New Wiseco 82.5mm coated top & skirt 8.1:1 pistons
-New Iroz I5 tubular exhaust manifold
-New 12mm ARP head studs
-ARP main studs
-10k km (yes, since NEW) ported head with new +.5mm exhaust valves, high rate springs, new seals etc
-7a cams
-could include new Iroz downpipe. Built for quick spool valve geo in a UrS chassis, vband/Stromung fitment
-could include ported and gutted AAN intake manifold
This setup will rev to 8500rpm or whatever you feel safe taking the stock oil pump to. Ideally this would be a high boost (over 30psi) pump gas engine. Ie. Big turbo in its higher efficiency range.
$5k plus assembly mentioned above if desired
-NLA 92.8mm crank
-ARP main studs
-7a cams
Re: Your dream built, bored out, high boost, stroker engine.
Do small children count as currency....?
If so, I'll take it.
Wish I had money and a second car for that.
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
oh em gee
i do not fn want to see this right now
PMd
- amd is the best
I should buy all.
Dis + 3586/6466 +qsv +35psi.... Just saying
on my stinking phone!
- amd is the best
3794chaloux wrote:Dis + 3586/6466 +qsv +35psi.... Just saying
3794 would have a pretty tiny power band with an 8500rpm redline
2.5l + qsv... Shouldn't be too bad
5500-6krpm and over 800hp. :dunno:
You'll have to scoop up what crumbs are left after I'm done.amd is the best wrote:I should buy all.
I've phoned in my order to Matt directly and am awaiting a final price.
- amd is the best
I can't buy anything right now anyway :(
So it looks like, pending sale to Dustin, that we'll have a new Hank header with egt on cyl 5 and vband with tial setup for sale. $1100 shipped today :-)
Also a new Hank downpipe for qsv on a UrS car, $400 shipped.
Lastly, new supertech +.5mm inconel exhaust valves and high rate valve springs. $250 valves, $200 springs
Bump, the engine is Dustin's. The above is for sale as mentioned. New thread maybe?
