Hanks URQ 2.6L Autopsy
Re: Hanks 81 URQ, O1e installed, paint squirted... Assembly
I had to take a break to go to school and do my school work, but I am scheduled to be back at the shop in a couple of hours. I have already put in 7 hours though today down there :)
Rear glass is in, trim is painted for hte most part, and the doors are 100%. I will probably save them for last, as to not bang them up getting carpet and seats back into the car.
I did let escalation get the best of me though.. I did the headliner in MicroSuede, taking advantage of the glass being out.. I also did the B and C pillers so I could put glass back in. They look really nice. I will eventually get the door cards, and other stuff done in the same material, but I gotta start lookign at the nessisary :) I only have zebra crap on door cards now!!! I dyed the carpets black in a fit of brown hatred. hehe
Thanks again to Martin. The rear window went in without a hitch and looks fantastic!
Highlander
Post by Highlander »
Hank,
Your a brave man for taking on such a task in such a short time.
Way to go.
total respect.
:drive: :cheers:
Craig
Quattro v1.0
Post by Quattro v1.0 »
When I heard control arm bushings yesterday around noon I was thinking 'nutjob' now i read 'headliner in ultrasuede' and Im speechless lol
savagerocco
Post by savagerocco »
You're a wild man Hank...... All I am trying to do now is throw my b4 hood on the car and hopefully some paint....
quattro87
Post by quattro87 »
Hey Hank, maybe when you get down to Vegas we can just find a quiet spot somewhere and nap. I'll be ready for one by then.
LOL!!
Dad, David has been a trooper in helping. He picked me up at 3am twice this week to get some work done in secret... Yesterday he asked my schedule for the next day and I told him that at some point, we ought to rest one of us as the driver.
a_CQ
Post by a_CQ »
Is it done yet?
stiroz
Post by stiroz »
Hank; maybe we just buy some stock in Monster energy drinks... Good thing all my patients are shakeing to much to notice my shakeing hands :) .... come to think of it why are my patients shakeing so much lately??
ralleyquattro
Post by ralleyquattro »
ShavedQuattro wrote: Thanks again to Martin. The rear window went in without a hitch and looks fantastic!
You are welcome, glad it went to good use.
If you need anything else, let me know.
Car is going to be brilliant... may I suggest going to the quad light setup.
IMHO it looks much more aggressive than the single light setup, yes Craig, you were right.
Cheers
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
a_CQ
Post by a_CQ »
Martin, quad light with euro bumpers? Got pics?
Hank, is it done yet?
84urq20v
Post by 84urq20v »
Quads look great IMO. As long as you push in the US bumpers or have Euros. Even tho I have slanted Euros - I think about converting back to a Quad H1/H4 setup....
Looking forward to seeing this car in 55 hours!!!!! :woowoo:
Buckets
Post by Buckets »
a_CQ wrote:Hank, is it done yet?
How about now?
Twintowers
Post by Twintowers »
What is the exact color, LY3D Tornado Red? You Decided to not use Pearlecent White? Looks great is single stage or two stage paint ? :?
I would use a small diameter piece of polypropylene rope inside the rubber seals channel, set the glass into the seal, set the bottom edge of the glass into the frame closest to the dash, start one end of the rope in the seals channel on the bottom left side of window frame wrapping the rope into the channel over the top to the bottom right of the frame, trim the rope length as necessary, have someone on the out side to apply light pressure to the edge of the glass as you pull the rope out of the seals channel as you work from the inside, the rubber seal will now lip over the A pillers body weld seam etc over, and around, I would alternate left to right until you get to the top center. It's pretty simple guy I know that worked at a glass shop showed me the technique. I would then use non harding automotive glazing putty to complete the seal, this will keep water out for sure, you want to seal both the outer glass to seal then the body to seal mating surfaces. You can use eurothane class sealent but the stuff is like glue once dry, and should you have to remove the glass in the future it will be a real bitch to remove probably ruin the rubber seal I recomend the non harding glaze.... Make sure you clean the rubber seal real good before you do this process there will be old glazing that should come off with a flat blade screw driver, you can repeat this process for your rear, and side windows, makes installing classic car auto glass a cinch! :o
quattro87
Post by quattro87 »
It's a 2 stage red that's pretty close to Tornado but the tornado color code wasn't used when the paint was bought.
ralleyquattro
a_CQ wrote:Martin, quad light with euro bumpers? Got pics?
This is sort of what Hank's car looked like when it was new.
Cheers
Martin Pajak
91 Coupe Quattro
quattro87
Post by quattro87 »
Cheers
Except in Port Rose. :-)
Well?
a_CQ
Post by a_CQ »
is it done yet?
RSCoupe
Post by RSCoupe »
:stupid:
I still have 10 hours. I am going to sleep for 2, as my productivity has gone down a bit in the last 2 hours. The interior lacks very little, and really the only things are doors and the front grill. When you go home and take a shower, and you put shampoo in your hair then conditioner, and then body wash in your hair, It is a bad sign of your mental state.
I am having some transmission issues with the linkage. I torqued down the motor and trans mounts, and now I dont have reverse and a stuborn 5th.. I think I may be rubbing somewhere..
More tomarrow.
WOMBAT
Post by WOMBAT »
ShavedQuattro wrote:When you go home and take a shower, and you put shampoo in your hair then conditioner, and then body wash in your hair, It is a bad sign of your mental state.
I've done that a few times... good luck on the final push!
a_CQ
Post by a_CQ »
You don't need 5th or reverse. So much power you can always 'spin' the car around....
