Haenszel - B5 Avant VR6 Turbo - Now 812whp 734wtq
Re: Haenszel - B5 Avant VR6 Turbo
Oh, for sure. That 1-2 shaft setup Is probably good for half a second atleast on a 10 second car, mainly because of the ratios. It also gets rid of the weakest part of the 01e, and that is the shifting mechanism 1-2. People bust updated parts all the time as well, so maybe a 1-2 shaft setup would break even over a 3-4 year year period
Good rationalization huh?
It was really. 1) I'd have to buy a new S4 input shaft anyways and 2) the new collar setup. That right there is essentially half the price of the gears. Sure it was a chunk of change, but it'll take care of the one MAJOR shortcoming of this car.Hank wrote:3K isn't too bad when you justify that you don't need an updated 1-2 collar and syncro. Good rationalization huh?
'00 a4 Avant - VR6 Turbo 6766 - 812whp - 10.201@143.35
Oh I agree with that, and I can't say I'm not super jealous!
- speeding-g60
all around win. the input shaft is bucks on its own you better off buying a whole trans used.
Yeah, full list is crazy money.
Brian, did you twist that Imput shaft with the dx700 or the 850?
850. I never had the 700 with the vr6, that was back when I had a 1.8t in the a4. Everything was fine until one day I did a low-speed 4th gear pull at 39 psi. I've never felt more tq/accel in my life, had to have been over 800 ftlbs. From there, the clutch slipped (blew off kevlar material) and when I pulled it apart it had twisted at the bottom clutch disk area. the other disk was just fine.Hank wrote:Brian, did you twist that Imput shaft with the dx700 or the 850?
Sounds wicked!
- amd is the best
Saw this at carlisle and was like, damn that's a sweet VR turbo widebody avant but that was really it. Had no idea it was an 800whp monster! Awesome car man! Jealous of the PAR setup...It'll be in my future as well I'm sure. I have a horrible track record with 01e's and I'm soon to have two cars equip with that money pit of a transmission.
Hah, well its not a wide body, its just factory fenders pulled quite a bit and rolled. And back when I went to carlisle it was about 500hp. Maybe I'll be able to make it again this year. When is it?amd is the best wrote:Saw this at carlisle and was like, damn that's a sweet VR turbo widebody avant but that was really it. Had no idea it was an 800whp monster! Awesome car man! Jealous of the PAR setup...It'll be in my future as well I'm sure. I have a horrible track record with 01e's and I'm soon to have two cars equip with that money pit of a transmission.
What problems did you have with the 01e?
crimson ghost
First time I've seen this car.
Thanks for posting !!
glibobbo21
may 17 18 19. please bring it again! maybe ill bring my avant if the 07k 4kq doesnt make it
EPIC setup!
'93 90q- 3m Matte Black Vinyl wrap, 17x8 et30 Rotiform BLQ, Koni Yellows/Vogtland springs
'90 Coupe Quattro- Project
Oooof. that's the same weekend as SOWO. Already have my place booked for then with a bunch of friends...... but..... carlisle is certainly a closer drive!glibobbo21 wrote:may 17 18 19. please bring it again! maybe ill bring my avant if the 07k 4kq doesnt make it
Small things right now while waiting for transmission parts.....
Moved up from a 10.5x24x3.5" core rated at 666HP to a 4.5" core rated at 900HP. Hope this frees up some HP's and it was a pretty easy swap, too. Minimal trimming.
No engine in the car yet, obv.
Also sacked up and ordered a set of front DSS axles instead of trying to make something work. Also going to install a water/meth setup with a couple large nozzles that can be controlled by the ECU to kick on if IAT's are still out of control. In case you didn't notice I'm going for better charge cooling this year.
As of today... E85, 39psi, 12v VR6 on 6766
- amd is the best
So much win.
- speeding-g60
sounds pretty badass, Dr B-rain.
the power UNDER looks pretty Effin great, too!!!!
That is just plain awesome. Need some street videos!
Frick, that's bad to the bone. x2 on the street videos!
Whoa
soooooo....roll races with 1000cc bikes yet?
All of these videos are at 30lbs from this past week. I don't have anything yet after yesterday.
Still on a 3" catback also. Was debating pulling that off to just run the 3.5" downpipe and see what the results are from that but that felt like too much work while it was strapped down on the dyno.
