The day i got the car out of the barn and got it running again.
I decided that the flat black spray paint sucked so i chose to paint the car in a swedish snow camo pattern. it is my winter car after all lol.
My next decision was that CIS sucks and that the car could run far better on digifant 1 EFI. so i ventured into the unknown and started setting up DF1 and tuning it N/A.
The first intake setup that i didnt like because the filter keep getting wet and muddy.
The second intake setup that worked very well using the 300ZX turbo hood scoop to get fresh air.
Me and my brother decided it would be fun to setup a rally course on the 500 acre farm my family owns. it was great till i slid off course into a swampy part of the field. this is the first time i ever got a quattro stuck.
My 4000 and my brother's 8v scirocco.
had to use a farm tractor to get it unstuck. even broke the drive shaft on my little brothers F150 trying to get it out.
The aftermath. ripped the core support right out of the front of the car. turns out the tow hooks where pretty rotten as they ripped right off the frame rail.
Time for another front core support. i figured while i was in there i might as well add a turbo too.
Bone stock JT engine finally gave up the head gasket. im impressed that the JT too 15psi as long as it did!
Time to freshen up the old JT with all new goods.
Built a new bumper support out of box tubing. also added a tranny cooler from a mercedes benz 300TD as an oil cooler.
Added HID hella 4000 rally's instead of hell 500's. plus fitting bumper cover with merc trans cooler mounted.
Bought a set of blizzak's used and they came with free wheels lol.
Secondary air pump was stupid so me and my brother designed and machined a block off plate for it
Interior shot with MK3.5 cabrio front seats, IMP steering wheel, AEM wideband, and schroth rally 4 harness installed.
Decided to put the later 85-87 rear bumper cover on.
Ebay front mount intercooler install
Than the 20v turbo got to be boring so i decided it was time to upgrade to the legandary 20V turbo.
This is my donor car i picked up for 1200.00 bucks. car was still inspected and registered for 2 months. and i drove it for that 2 months before dismantling it.
engine removed, cleaned and started powder coating parts.
Time for one last rip on the 20v turbo. i attend one local car show a year and i was going to make sure the old quattro displayed its power.
New larger front mount intercooler.
installed gray cloth recaro's because the MK3.5 cabrio seats sucked.
Picked up a digital dash from a coupe GT.
Painted my intercooler pipes to match the car for something different.
Larger intercooler installed.
Refinished my stock wheels with harbor freight gloss white powder coat.
Wired up the whole factory bose URS4 stereo with 10 disc changer. i've never heard a 4000 with a better sounding stereo.
Time to install AAN engine!!!!
20v turbo out!!!!!
Screamer pipe fabricated.
AAN in its new home.
The wiring nightmare.
Battery tray gone, URS4 plug rack installed, URS4 ICM bracked installed, URS4 fuel filter bracket, URS4 positing battery junction installed.
Power steering reservoir and washer bottle relocated.
Machined a few 7A flywheels down and added the single timing pin.
URS4 false floor installed and wiring complete under the dash.
False floor cover installed.
Everything fabricated and reassembled, its time to go scare the crap out of myself lol.
A few pics my buddy frank took of the car.
Messing around with turbo volvo wheels. their 5X108 so one bolt hole lines up. i think the car looks bad ass with these on it.
As of recently the AAN spun a rod bearing and chewed the crank up. Now im in the process of assembling a ghetto 20VT for it instead using an NG 2.3 bottom end and the head off of my AAN engine.
the NG bottom end cleaned with the rods & pistons removed.
Pistons ready to go to the machine shop with my brother to have valve relief's machined in.
And thats where i stand at the moment with the car. i still have to tear the AAN back out and strip everything off of it yet too.
