worked on diagonals in the floor, and the seat-crush protection crossbar. then the eyebrow bar.
working on this all this weekend.....
this catches us up to Saturday evening. i think i have the 3rd member now. havent committed to it yet, but i think i am going to. 4.30 Pro gears, lightened ring gear. 40 spline steel lightened spool. Strange aluminum case, forged yoke, Pinion support, and yoke collar thing. all set up and ready to drop in. came from a 7.20's '63 glass body Vette drag car here, one of the builders buddies. it was his backup, wrong ratio for him.
Got some more crap out of the way of the dash bar, and put it in. Then I started on the funny car cage portion. I messed up the very first bar, and I dont know if we can save it. I will work on that tomorrow. I hope to have the whole cage portion tacked into place and the roof bar also. It may be wishful thinking but whatever.
Also, test fitting a seat so I can build the cage portions around it. Kirkey drag seat.
Sooo, we were able to save the piece I thought I eff-ed up yesterday, but it made the two back bars near impossible. I messed around with the outer bar behind the seat for about 3 hours, and finally we just cut the rear halo leg off the hoop and coped that bar into it. It will be fine but I was not trying to chop up that halo bar.
Then, on to the harness bar and helmet bars. Tomorrow I will go in and try to knock out the rest of this portion of the cage. It is a lot of work, this cage/chassis building stuff! And of course, he needs everything dead nuts perfect! 00.1° is not acceptable….. 00.0° is.
