I got everything done. I need to bleed brakes once more. change the oil again. and get alignment. I would love to get the driveshaft shortened this weekend.. I have NEVER been to Carlisle, I have bought tickits, and food, and camping 3 times and had either something come up with work, family, or the car and never made it the 3 years I paid and registered to go.. BUT THIS YEAR ITS ON... FIRST TIME EVER, the old lady and kids are going away that weekend with down to her grandmothers, so I am totally free to go.
since there are no sleaved ends on the cq shaft, which would have been my easiest and was my plan of attack for shortening this. I didn't get much sleep last night and after laying in bed these are the only options I can come up withl.. leme know what u think please or if you have any input on another route to tackle this. so I can go to Carlisle Quattro style for the first time ever..
(1.) cut the shaft and Remove ~5". then machine a 3" sleave that slides into each end of the cut shaft tube and weld back together.
(2.) cut the cv end off where meets the shaft tube itself. the spot I think looks like a press fitting. The first pic below. THEN machine the ends outside diameter to fit inside of the shortened cut shaft tube. and WELD
(3.) longshot but maybe if anyone has info on oem audi shaft lengths, if I can find one that is 4-7" shorter then a stock cq length I might be able to make it work. I can still move the motor about 1.5" front and back with the slotted motor mounts I have, and/or move the rear to fit the ds if I found 1 that's close,
If memory serves me correct I thought I Read awhile ago that v8 auto shaft was close to the range shorter I am looking for.. but I also thought they had a long nose rear as well.
I plan to keep the stock cq rear. it can hold what I need it too. its one of the smallest lighest audi rears and I have a few spaires on the shelf.
Thanks in advance for any tips or advice.. I appreciate the help. without you guys, I wouldn't have the car I do now, I would have spent a lot more time and money just doing the trial and error route, which I certainly prefer not to Fucck with especially being a spinning drive shaft
Inside and outside pics. They look the same at each end front and back, both inside and out.
Is this pressed together or ?
--- In Option (2.) i thought to machine this cut end so the outside diameter would just tightly fit inside the cut drive shaft tube itself.
91 VEMS CQ vr6 6766 o1e s2.
01 GTI vr6 vems 6262
01 2500 Cummins hx40. Tow Rig, vems round 80psi
