Thanks for the bump
What I thought was bad gas ended up being a combination of sorts. Yes, I did get some bad gas from a crap gas station. I also ended up with a chewed up plug wire because it got all caught up in my steering rack! After I found it and replaced it, the thing ran smooth. Did a couple log files and got some tunes back. Ended up with around 20psi in 3rd.
The next thing would be to improve the start up (it hates the cold weather) and idle. Whenever I shut down the thing it doesn't do it quite smoothly and I think it just needs some fine tuning I'm unable to do. Which brings me to my current game plan:
- Purchase 01E 5 speed - done
- Purchase Iroz Motorsport trans mounts - in process
- Locate and purchase 4000 driveline - in process
- Flush out trans fluid and cleanup trans
- Install all that fun stuff
- Install new (used) dashboard that's in way freaking better shape.
- Rebuild all the chassis fun stuff: Subframes, control arms etc. This includes stripping and painting before reinstall.
- Purchase Iroz Motorsport K26 Hybrid - in process of saving
- Drive down to Iroz Motorsport for a day of tuning
I also found a daily driver/commuter. A 2000 Jetta 2.0 with a 4 speed automagic. It's a decent car that's comfy and doesn't promote fast speeds. Plus my wife can drive it which is nice when I need to use her truck. It'll be very nice to have a commuter and be able to work on the 90 as I have time and not worry about getting it ready to drive to work the next day.
Do I regret going with a stand alone ECU? Not in the least bit. I love the fact that once I get this K26 I can simply take some log files, get a new config and run it. Even more now that my car is solely a project car.
