Matt's 1995 Casablanca Urs6 Build!
Re: Matt's 1995 Casablanca Urs6 Build!
Sounds like it's gonna be tight. There's gotta be room for a big cooler on the driver's side...
CassaUrS6
Post by CassaUrS6 »
I'll post pictures tomorrow Ed of why I didn't move it over to that side. I built a 10x6x6 aluminum tank to hold more coolant for the ic system that's in the location of the Stock Ic.
Ah, gotcha.
Stock oil cooler doesn't match the rest of the build... I would try to find a way to get fit something bigger, somewhere.
So pushy!
Lol :)
Just looking out for everyone's best interest :D
Troof, oil Temps are a bitch to keep under control.
CassaUrS6
Post by CassaUrS6 »
EDIGREG wrote:Ah, gotcha.
LOL, 5$ to any one who can find a place for it!. Here's some pictures all plumbed up before it comes apart for paint and final assembly.
The filler cap mounted high, need one more piece of hose
Pump placement, bracket will be built today
In front of condensor maybe? Top portion...
CassaUrS6
Post by CassaUrS6 »
the hood wouldn't clear a 2'' thick oil cooler, and they don't really make any -10 fitting ones that are less then 2'' thick
Not much extra room.
lots of hours in the fab as is.
amd is the best
Post by amd is the best »
I have never had an issue with the factory cooler. Maybe on a road course it would become and issue but on a street/strip car where the most it will be is WOT for 10-20 seconds it will not be an issue.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
That's what I've been thinking as well...
Sure if you're only using WOT for 10-20 seconds then you won't have any issues....is that really the hardest you drive your car??
Any repeated WOT activity like a road course or driving twisties on the street where you're accelerating out of each corner banging off the rev limiter :) and the stock cooler is insufficient, specifically with big turbo/higher power band.
Protect the most important parts of your engine!
amd is the best
Optimal oil temp, based on my research is between 230-260°. For as hard as I've ever driven my 200 it has never surpassed these temps.
Some people will just blindly bolt an oil cooler on their cars when it's not needed. Then the oil is below ideal. We'll obvoisly watch temps though.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best wrote:Optimal oil temp, based on my research is between 230-260°. For as hard as I've ever driven my 200 it has never surpassed these temps.
if the oil cooler thermostat is working properly even the biggest oil cooler should allow the temps to reach 230F. it doesn't open until around there so the water boils off.
The AAN has an oil cooler thermostat. A larger cooler will provide better cooling capacity and efficiency, not cause oil to run under operating temp.
Obviously 200 20Vs are better at cooling oil than urS4s are.
I never once saw oil temp rise above normal in mine, but I probably just drive like a puss.
I agree on the thermostat statement though.
loxxrider wrote:Obviously 200 20Vs are better at cooling oil than urS4s are.
Does the 3B have a different cooler?
Sarcasm doesn't translate well over the Internet, but I'm not sure? Could be! I was serious about the rest though. Like I said, I probably just drive like a sissy.
Oh, lol I see the sarcasm now /duh
amd is the best
3B's have the thermostat and what looks like a very similar cooler (if not identical). 200's are superior though.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Like ^^^
Lol here we go. Get out of the urs6 thread you t44 butt-buddies
amd is the best
I have no choice but to be involved with this vehicle ED.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Did you purposely capitalize both letters in his name so people would mistake it as the acronym for an unfortunate male problem? That's uncalled for man. :thumbsdown:
