I have little energy so this post will be short.
Got stuff all buttoned up and ready for fuel pressure test. The back banjo leaked a little so I pulled the banjo off, took the washer to some 1000 grit sand paper lightly, cleaned and reinstalled. That seems to have done the trick.
After I confirmed no fuel leaks, I setup the VEMS computer to log and turned it over. 2 seconds later it fired up! First try! Had to get some more power steering fluid so I took a break and came back to button up everything. Got the coolant system air'd out then took it for a drive.
Seems to run smoother now with the coils, injectors and 4bar map. We'll see what the log file looks like after I send it to Marc tomorrow.
Can't find the lower headlight trims but no matter, after this week it and a shop clean it goes back on jack stands for chassis updates! Can't decide if I want to tackle the trans swap but I probably will. those updates will be fun and they may not take as long. . .
After that I'll probably get tuned for E85. I mean, the station is less than 10 miles to work and on the way to school next semester so why not?
Pics because yippers:
