VEMS standalone, 7 bar map, dual wheel speeds, knock and egt
car is a stock block, stock compression, stock head.
only runs on e85 and I use the ID 2000cc injectors.
I have parts for a second motor with oversized valves and some porting but I want to see how far I can push this stock motor first.
This winter I plan to finish the cage. and rebuild the rear end suspension and mount components.
need to change exhaust still, my muffler is a tad low in the streets with the small tire setup on it.. was fine with the 17s
